Old 07-18-2002, 05:45 PM   #1
halyoder
halyoder is an unknown quantity at this point
Send a message via AIM to halyoder
has anyone done this cause i looked on heavy throttle's web site and this is what it says....
"There are about 12 wires that run from the ECU up into the dash, those will be cut.   The following wires matched up perfectly on both the SR ECU harness and the KA dash harness:
Yellow / Red stripe - Tachometer signal      Yellow / Green stripe - Speedometer signal
Orange - Ignition start      Black - Ground      Blue / Green stripe - AC signal
Blue / Black stripe - Water temp signal
These were cross-verified in the 90 KA FSM and are correct.
On the KA, the rest of the wires (green, gray, light green, purple, red / yellow stripe, gray / yellow stripe) all are listed in my KA FSM as going to the 'check connector'.   I'm not sure but I think the rest of the wires on the SR ECU harness (green, green / black stripe, green / red stripe, green / white stripe, orange / black stripe, Red / white stripe) go to the 'check connector' also.   I have not hooked these up"
my colors on the other 6 wires are different then thiers. what do i do please any info would be great. i think they are wiring up to a sohc wiring harness and i'm using a dohc cause my car is a 91 240sx please help!!!!!!!
www.zerolift.com
halyoder is offline   Reply With Quote
