Old 07-18-2002, 07:18 PM   #1
redracer240sx
redracer240sx is an unknown quantity at this point
In the intrest of saving me time of tearing down the distributor just to find out this simple fact, can somebody tell me which direction advances the timing of a KA24DE? turning it toward the timing cover, or toward the flywheel? what is the optimum degree adv/ret?
Thanks
Caleb
redracer240sx is offline   Reply With Quote
Old 07-19-2002, 08:08 AM   #2
240 2NR
240 2NR's Avatar
240 2NR is an unknown quantity at this point
Advanced is toward the front of the car (turning the distributor counter clockwise). On a DOHC, the stock setting is 22 degrees +/- 2 btdc.
Optimal setting depends on what your doing and if you have access to a dyno. In general if you run premium, you should be able to safely run 24 degrees without problem and any more than that and I'd want a dyno to verify where power is made or lost. Rememeber, the further advanced you go, the more risk you take if you ever fill up with regular gas.
-edit-  because %%d doesn't make a nice little symbol for degrees
Steve
93 240sx FB currently very clean and for sale
240 2NR is offline   Reply With Quote
Old 07-19-2002, 07:48 PM   #3
MarketPlayer
MarketPlayer is an unknown quantity at this point
To do this you would have to? take off the dist cap, rotr, then what...
MarketPlayer is offline   Reply With Quote
Old 07-19-2002, 10:30 PM   #4
Joe_M
Joe_M is an unknown quantity at this point
Send a message via AIM to Joe_M
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (MarketPlayer @ July 19 2002,8:48)</td></tr><tr><td id="QUOTE">To do this you would have to? take off the dist cap, rotr, then what...</td></tr></table><span id='postcolor'>
Nope... leave it all together. &nbsp;All you have to do is loosen the 2 10mm bolts that hold the distributor to the block, turn it a few mm towards the front of the car, verify the timing with a timing gun, then tighten down the bolts. &nbsp;Easy as pie.
Joe
1991 240SX LE Fastback SOLD!!
1992 USDM OneVia CA18DET powered SOLD!!
1996 240SX Base Model Rockin' the 4 Lug
1995 240SX Base Model $400 project car... and it runs!
Joe_M is offline   Reply With Quote
Old 07-20-2002, 03:52 PM   #5
shady
shady is an unknown quantity at this point
what are the benefits of advancing the timing on a 240sx ?
shady is offline   Reply With Quote
Old 07-29-2002, 08:19 AM   #6
anotheraznguy
anotheraznguy is an unknown quantity at this point
Send a message via AIM to anotheraznguy
you get more hp...
but i have a quick question..
how do i use a timing light?
can anyone give a detailed instrustionc..
anotheraznguy is offline   Reply With Quote
Old 07-29-2002, 11:10 AM   #7
240 2NR
240 2NR's Avatar
You're best off watching someone who knows what they're doing &nbsp;the first time. &nbsp;That's how I learned and I think if I read about it I still would have been lost without a lot of pitures.
A timing light clips to the battery and the #1 spark plug wire. &nbsp;The gun is then aimed at the serpentine belt between the block and fan shround and you will see a series of lines. &nbsp;The lines indicate degrees advanced or retarded based on where they are in relation to a timing mark. &nbsp;The gun is basically a strobe light that illuminates as the spark is fired so you only see the instant it fires, and allows you to guage the position of a timing line against the mark. &nbsp;
A basic gun just flashes as it fires so where the mark is tells you the degrees. &nbsp;Others are more advanced that can show you where 0 is and allow you to do other fancy things I don't completely understand. &nbsp;
This probably doesn't help much at all (it wouldn't help me aside from understanding the basics). &nbsp;Find a friend who is very good at working on motors and chances are they have a gun and will be able to advance the timing on your car in five minutes.
Steve
