Old 01-15-2007, 01:23 AM   #1
arian23
arian23 is an unknown quantity at this point
s14 I Need help on Engine Removal and Install. S14 KA
I am about to change the long block on my car and reintall a new KA24and I was wondering if there any tips and tricks to doing it. Is there any threads to this? I tried using the Search Mode but it doesnt work. So dont sit here and try to flame!
arian23 is offline   Reply With Quote
Old 01-15-2007, 01:49 AM   #2
street240
street240's Avatar
street240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nice
I can give you some tips. Some I learned the hard way. 1. Drain everything 2. make sure everything is absolutly disconnected before you try and hoist. Other than that it is easy. Good Luck
The Gallo 24 would be a better motor for my skyline...But I am waiting on the swap dvd...
street240 is offline   Reply With Quote
Old 01-15-2007, 02:18 AM   #3
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
if you search google youll probably find something. make sure to take out your power steering lines, if youre taking the tranny and engine out together. If the tranny catches them youll be looking for new ones. Drain all the fluids like said above, and its easier if you take out the radiator and fan. (more room)
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 01-15-2007, 02:21 AM   #4
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
If you dont know where all the harness plugs go label them.
When you re-install make sure you have the mounts already attached to the motor, so you just have to slide the studs into the chassis.
Pull out the trans and engine together, much easier and a lot less time consuming.
Dont lose shit, keep your workspace clean and organizied.
And Zilvia's search not working is a terrible excuse. Ever heard of google? There are 284703247 step-by-step threads on like 4 different forums on how to remove engines.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 01-15-2007, 03:23 AM   #5
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
check out some build-up threads becuase they often times have lots of photos while theyre removing the engine. you can look at their examples and try to deduce something from it.
just take your time and make sure all wires/lines are disconnected.
remove intake and all that junk first. then all the wiring and lines. then remove radiator so you dont damage it/have more room to work with. and just make sure all your fluids are drained. then go rent / barrow an engine hoist and remove that sucker. its not very hard at all.
Helps to have a buddy or two to help guide the engine and tranny out of the car.
redsuns3838 is offline   Reply With Quote
Old 01-15-2007, 04:27 AM   #6
!Zar!
!Zar!'s Avatar
http://heavythrottle.com/
Last I checked, they had a pretty decent writeup on ka removal.
By using that, and some common sense you should be golden.
Old 01-15-2007, 04:41 AM   #7
BoostinGST
BoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant futureBoostinGST has a brilliant future
+1 on the power steering lines... i found out s13 lines work on an s14 though the only thing i can add to this is take your time, if your doing an sr20 make sure you do your heater core lines before the motor is bolted in... much much easier.
BoostinGST is offline   Reply With Quote
Old 01-15-2007, 05:49 AM   #8
iiEddieGii
iiEddieGii is a well-known jackass
Send a message via AIM to iiEddieGii
Recently, I found a new magazine in a bookstore (books a million) called "Project Car" that has all the steps to take out the KA and put in the SR. It was a quarterly magazine so it should still be for sale.
iiEddieGii is offline   Reply With Quote
Old 01-15-2007, 05:08 PM   #9
EfiniGirl
EfiniGirl is an unknown quantity at this point
don't bother discharging the a/c
just unbolt the compressor and tie it up on the side
you don't have to take off the p/s lines if you're careful about it. the nuts on the p/s lines are easy to strip. if you do take them off, be careful.
EfiniGirl is offline   Reply With Quote
Old 06-07-2011, 11:32 AM   #10
JKL1031
JKL1031 is an unknown quantity at this point
im sure there is a how to thread on this. Anyone know exactly where?
JKL1031 is offline   Reply With Quote
Old 06-07-2011, 11:42 AM   #11
theboy
theboy is an unknown quantity at this point
ya, heres your how to for bumping a 4 year old thread.
Step 1: Google search - engine swap ka24de
Step 2: Cut front end off car just in front of fire wall (biggest saw you can find)
Step 3: cut front end off donor car (same place)
Step 4: mix paper mache (secret tip add super glue for stronger bond)
Step 5: paste new front on old rear, using plenty of paper mache that you just mixed
seriously dude, its not rocket science to pull a motor. And if you cant figure it out on your own, then you probably shouldnt be doing it. Good luck getting spoon fed through out life tho.
theboy is offline   Reply With Quote
Old 06-07-2011, 03:23 PM   #12
JKL1031
Thanks for your help.
Old 06-07-2011, 03:50 PM   #13
nighthawk48
Trader Rating: (26)
nighthawk48 is an unknown quantity at this point
Feedback Score: 26 reviews
lol to this
nighthawk48 is offline   Reply With Quote
Old 06-07-2011, 03:57 PM   #14
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
DAww,
I can't help but feel for the guy. He took that butt kicking and thanked you.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 06-07-2011, 04:16 PM   #15
JKL1031
I was really looking for a how to or one of those write up threads that I know exist on stuff like this. Thats all really.
I have: an idea of how to remove an engine, my dad whos done it on older cars, and some beast co-workers with forties that will help, but never did it myself. Wanted to read as much as I can first.
Old 06-07-2011, 04:16 PM   #16
camaro379ss
camaro379ss's Avatar
camaro379ss is an unknown quantity at this point
Kinda unnecessary.
I know this isnt your exact situation but maybe it will help you find something you are looking for....
http://www.nicoclub.com/archives/ka2...p-by-step.html
http://forums.nicoclub.com/s13-ka24d...l-t299950.html
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp
camaro379ss is offline   Reply With Quote
Old 06-07-2011, 04:35 PM   #17
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
I do the whole job for 850$$ U.S.
Old 06-07-2011, 04:39 PM   #18
daryl337
daryl337's Avatar
fantastic information for the guy. +1
Old 06-07-2011, 04:43 PM   #19
JKL1031
Thanks, that second link looks good. my labor budget was $500, and trust is important as well.
Old 06-07-2011, 07:34 PM   #20
Robb
Robb is an unknown quantity at this point
Use containers to keep bolts in, label plugs, drain fluids, pull at the motor as a set.
Oh, and pay attention to what you're doing.
www.PictureMeDaily.com
Robb is offline   Reply With Quote
Old 06-07-2011, 07:57 PM   #21
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
You can have that thing out and re installed with one extra set of hands in like 2-3 hours. 240 is the easiest car to work on and some what cheap. But it's a cheap money pit.
SLiDe_WaYz is offline   Reply With Quote
