Old 07-20-2002, 07:51 PM   #1
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
did anyone who put on eibach sportlines and tokicos, or any combo with the sportline springs have camber problems afterwards? and will my 245's rub on the back? will i need spacers for the 8-1/2 inch wide 300zx rims?
thanks any help is appreciated
'97 maxima 5-Spd
Nismos14 is offline   Reply With Quote
Old 07-21-2002, 10:24 AM   #2
Nismos14
Nismos14's Avatar
somebodyz gotta have these huh? and they claim 1.7 inch front and 1.4 inch back, is that accurate?
'97 maxima 5-Spd
Old 07-22-2002, 11:28 AM   #3
sporty240
sporty240 is an unknown quantity at this point
Send a message via Yahoo to sporty240
yes, I'd like to know the same thing. I've got a set of Sportlines sitting in my race shop right now waiting to be popped on, but no one can tell me if i'll need a camber correction kit. I've got a '92 S-13.
btw nismos14, sportlines are 2.4 front, 2.2 rear for an S13. The pro-kit is 1.8 drop, my buddy has them on his '93 240 and they barely help that hideous wheel well gap.
-Ben
'92 S13 tuned by Team Auto Expressions Performance
Injen CAI
Tornado
NGK Wires
PDM Strut brace
Bosal Brospeed muffler
Eibach Sportlines
Tokicos
Kenwood receiver/Kappa speakers/Thunder8000
sporty240 is offline   Reply With Quote
Old 07-22-2002, 12:17 PM   #4
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
I had those springs on my 240. IMO Save yourself a lot of trouble and get a camber kit installed too. You'll notice a big change in handling initially but it'll gradully fade if you dont go with a camber kit.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess
Ni5mo180SX is offline   Reply With Quote
Old 07-22-2002, 04:02 PM   #5
Nismos14
Nismos14's Avatar
well where do i get the camber kit, and how much? only for the front? or front and back?
'97 maxima 5-Spd
Old 07-25-2002, 10:43 AM   #6
Ni5mo180SX
Well theres two type of camber kits but the type you'll find most likely is the screw(?) type. Its been awhile but its only like $20 bucks for the front set and it just helps pivot the angle more so then stock. I just went with front set. $20 for the "kit" and probably 80 I think for the install and alignment.
Old 07-25-2002, 10:47 AM   #7
Nismos14
Nismos14's Avatar
you think they can be installed by urself?
'97 maxima 5-Spd
Old 07-25-2002, 10:57 AM   #8
Ni5mo180SX
Yea, just depends on how much exp. you have. IMO id just take it to the shop cause you're gonna need to get it aligned with the kit on there too. But if you think you can do a flawless job of installing it then go for it. Dont delay on the kit though, I lagged and thats what cost me my car.
Old 07-25-2002, 12:03 PM   #9
Nismos14
Nismos14's Avatar
how did it cost you your car?
'97 maxima 5-Spd
Old 07-25-2002, 02:11 PM   #10
Ni5mo180SX
Just cause I should have done it when I lowered my car. I went through my set of tires in about 4-5 months. Got new ones and ate those up in 3-4 months. All I had to do was pay a fraction of the amount for a camber kit at the beginning.
Old 07-25-2002, 07:07 PM   #11
sxfro
sxfro is an unknown quantity at this point
Send a message via ICQ to sxfro
i have sportlines on my 98 and the front camber was'nt off that bad but the back was off 3 degrees and i have not seen any camber kits for the rear,maybe soom pillow mount will help a little.
sxfro is offline   Reply With Quote
Old 07-25-2002, 07:49 PM   #12
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
i'm getting some pretty bad negative camber in the rear as well, do you guys know if i can adjust it?  My mechanic suggest i needed new struts (I'm getting new struts when I install my springs), just wondering what my options are.
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 07-25-2002, 08:15 PM   #13
Nismos14
Nismos14's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sxfro @ July 24 2002,9:07)</td></tr><tr><td id="QUOTE">i have sportlines on my 98 and the front camber was'nt off that bad but the back was off 3 degrees and i have not seen any camber kits for the rear,maybe soom pillow mount will help a little.</td></tr></table><span id='postcolor'>
did u do the struts and shocks? i do believe the rear is adjustable to a degree..... but 3 degrees of negative camber?? thats quite a bit
'97 maxima 5-Spd
Old 07-26-2002, 12:45 AM   #14
Ni5mo180SX
Nope I was using stock shocks. Well the front and the rear are adjustable but when the cars lowered theres only so much you can do. but yea 3 degrees is a lot. If you're in South CA let me know and I'll give you the info. on the shop I went too.
Old 07-26-2002, 03:53 AM   #15
KyoLo
KyoLo's Avatar
KyoLo is an unknown quantity at this point
yah, i installed my tokico heavy duty blue shocks and pro-kit eibach springs about 2 months ago, did the alignment about 1 month ago, DISCOUNT TIRE CENTER in SoCA told me my camber is "bad", new ones would cost $350!! WTF ...so i didn't do anything, but later on i asked my mechanics "N&J"'s Jackson, he said $150 will do, BUT THE FACT IS I HAVE ALREADY SPENT $50 for ALIGNMENT in DISCOUNT TIRE CENTER!!! i'm off -2.1 left, -1.9 right .......but they sell EIBACH Adjustment KIT for around $40 on autocarparts.com ...so i DON't KNOW WHAT TO DO NOW!!!! HELP!!
Signature Exceeds Forum Limits
KyoLo is offline   Reply With Quote
Old 07-26-2002, 09:51 AM   #16
240racr
240racr is an unknown quantity at this point
Send a message via Yahoo to 240racr
Whiteline sells a camber kit. Can't remember how much $. But it only adjusts +/- .75 degrees
Precision T3/T4, 65lb injectors, z32 brakes, AEM EMS, 360WHP
240racr is offline   Reply With Quote
Old 07-26-2002, 09:53 AM   #17
Ni5mo180SX
haha calm down. Well what kind of camber kit is the Eibach adj. kit? Most likely its screw type again (the other kit is usually in the 100+ range and havent seen one yet for the 240) So you can go with the Eibach kit or get the kit somewhere else for about $15-20. Just get it installed and your car realigned and everything should be ok &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Old 07-28-2002, 03:56 PM   #18
sporty240
can you please tell me where i can get this $20 camber kit? I'll order it as soon as i find it. &nbsp;also do I have to know the amount of adjustment needed before i can order it or does "one size fit all"?
thanx
-Ben
Injen CAI
Tornado
NGK Wires
PDM Strut brace
Eibach Sportlines
Tokicos
Old 07-28-2002, 03:57 PM   #19
sporty240
thanx
-Ben
Injen CAI
Tornado
NGK Wires
PDM Strut brace
Eibach Sportlines
Tokicos
Old 07-28-2002, 06:49 PM   #20
drift into a curb
www.tirerack.com has the eibach alignment kit. &nbsp;might be around $25 though. &nbsp;
Do you guys know if the negative camber problem on the rear tires I'm getting is due to the worn struts? &nbsp;I'm going to be lowering my car with sportlines/koni yellow combo, but I'd like to find out whats wrong with the rear for sure. &nbsp;I trust my mechanic, but I was wondering if you guys had this same problem and if you have corrected it.
Go big or go home!
