Code 55 question???
I am receiving a code 55 on my ECU. Has anyone ever had this code before and what was the cause after you had it diagnosed?
I am not sure if it has something to do with my car sputtering under boost. Thanks As you can see, I did some homework prior to posting. There are two digits in each code. Count the long flashes, then the short flashes (only count how many times the light is ON) and you'll have a 2 digit code. These codes are covered in the service manual. Code Meaning 11 - Camshaft Position Sensor 12 - Air Flow Meter 13 - Coolant Temperature Sensor 14 - Vehicle Speed Sensor 21 - Ignition Signal 25 - IACV - AAC Valve 26 - Boost Pressure Sensor 31 - ECM Fault 32 - Exhaust Gas Recirculation System 33 - Front EGO Sensor (O2-1 Sensor) 34 - Knock Sensor 35 - EGR Temperature Sensor 36 - EGR BPT Valve 37 - Closed Loop System 41 - Intake Air Temperature Sensor 43 - Throttle Position Sensor 54 - Signal from Auto Transmission 55 - Other Malfunction. CONSULT Terminal Required 63 - Cylinder 6 Misfire (?) 64 - Cylinder 5 Misfire (?) 65 - Cylinder 4 Misfire 66 - Cylinder 3 Misfire 67 - Cylinder 2 Misfire 68 - Cylinder 1 Misfire 71 - Random Misfire 72 - TW Catalyst System 76 - Fuel Injection System 77 - Rear EGO Sensor (O2-2) 82 - Crank Position Sensor 84 - Automatic Transmission Diagnostic Comms Line 95 - Crank Position Cog 98 - Coolant Temperature Sensor 103 - Park/Neutral Switch 105 - EGR Solenoid 111 - Inhibitor Switch 112 - Automatic Transmission Speed Sensor 113 - Automatic Transmission 1st Signal 114 - Automatic Transmission 2nd Signal 115 - Automatic Transmission 3rd Signal 116 - Automatic Transmission 4th Signal 118 - Automatic Transmission Shift Solenoid Valve A 121 - Automatic Transmission Shift Solenoid Valve B 123 - Automatic Transmission Overrun Clutch Solenoid Valve 124 - Automatic Transmission TOR Conv Solenoid Valve 125 - Automatic Transmission Line Pressure Solenoid 126 - Automatic Transmission Throttle Position Sensor 127 - Automatic Transmission Engine Speed Signal 128 - Automatic Transmission Fluid Temperature Sensor |
Where is that list of codes from? I just got a code 55 as well but on this link it says all is well:
http://www.ka24development.com/ecu_codes.html The list is a Probable 'trouble code' cause for Nissan vehicles 1984 and later |
yah I got a 55 back in the day and did a quick google search, came up just as meph said. I was pissed cuz car was running like shit, never did figure it out. but "everything was fine".
I was going to, but I can not think of a sig less than 75 characters. |
#5 |
![]() Join Date: Mar 2004
A Code 55 means the ECU diagnostic mode does not detect any errors.
So, either everything is working correctly or the ECU isn't receiving any malfunction feedback from any of the sensors. |
