Old 01-28-2007, 03:36 PM   #1
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
SR20 oil/plugs winter/summer
hey guys,
i picked up an S14 a few months ago, i need to do an oil change soon. what oil should i use? its cold in utah (30 degrees during the day, 15 at night) for a while. so what synthetic oil should i be using? also, what should i use in the summer time (100 degrees during the day, 65-70 at night)?
im having some issues with my plugs also, they were gapped to .30 and boost would blow them out, now theyre .25 and at .7 bar they still get blown out a little bit. is .22 too small? also, what is the stock heat range? i want to run colder plugs in the summer, what heat range should i use? what about in winter? warmer heat range?
sorry thats a lot of questions lol
thanks,
Greg
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 01-28-2007, 03:44 PM   #2
~Split~
~Split~'s Avatar
~Split~ is making a name for him/her self~Split~ is making a name for him/her self
Send a message via AIM to ~Split~ Send a message via MSN to ~Split~
as per recommendations from both XAT and Enjuku, i use the heat range 6 at 12psi. Enjuku says only use Iridiums, XAT says only use coppers. i saw from a chemistry standpoint that iridium is far better at dissipating heat and therefore should be used whenever possible. the downside is that you can't gap them, but they really don't need gapping. as i said i'm running 12psi stock turbo and certainly no signs of the BKR6E-IX being too hot or gapped to far open.
The Phoenix Touge Guy/ NEED TIRES
www.myspace.com/mid_baller10
~Split~ is offline   Reply With Quote
Old 01-28-2007, 03:45 PM   #3
~Split~
~Split~'s Avatar
idk how they could be blowing out thats somthing i want to know
try swapping the spark plugs for the ones i posted above
Old 01-28-2007, 03:47 PM   #4
yayo_blanco_chuki
yayo_blanco_chuki's Avatar
yayo_blanco_chuki is an unknown quantity at this point
Send a message via AIM to yayo_blanco_chuki
My NGK BKR7E-11's seem to be blowing out at around 9-10 psi. I have them gapped at .030" Going to see if an MSD coil will help out some.
91 S13 KA-T with GT28R.
yayo_blanco_chuki is offline   Reply With Quote
Old 01-28-2007, 03:57 PM   #5
EJ253
EJ253's Avatar
how much are MSD coils? i think i might do 2 stage launch control at the same time if i upgrade the coils.
Secret Society
Old 01-28-2007, 03:59 PM   #6
EJ253
EJ253's Avatar
whats the stock SR heat range?
Secret Society
Old 01-28-2007, 04:00 PM   #7
~Split~
~Split~'s Avatar
http://www.modacar.com/products/Nissan/240SX/MODAIGC
there is tons of places but this one is a good place for that part.
Old 01-28-2007, 04:07 PM   #8
EJ253
EJ253's Avatar
thanks.
can anyone answer the stuff about what oil to use?
Secret Society
Old 01-28-2007, 04:12 PM   #9
~Split~
~Split~'s Avatar
also use Royal Purple 10w30 oil for the summer because its heavier and it wont clog up the motor. but i use lighter oil weight in the winter
Old 01-28-2007, 04:16 PM   #10
EJ253
EJ253's Avatar
i was told something like 5w30 in the winter and 10w40 in summer. synthetic of course
Secret Society
Old 01-28-2007, 04:25 PM   #11
~Split~
~Split~'s Avatar
yea that works too the lighter in the winter and the heaver in the summer. if you think about it. sit out some light and heavy oil out side over night and watch the oil become stale and frezze up. of course u want the oil that is still liquid like and that would be the lighter and yes Synthetic is what u want to run in you car. same goes for the summer thing sit out side and do it. hahaha
Old 01-29-2007, 09:18 AM   #12
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
20w50 or 15w40 in the summer... just sticking with 15w40 through the winter i guess... but 10w30 would be best
nsn240 is offline   Reply With Quote
Old 01-29-2007, 02:47 PM   #13
PoorMans180SX
PoorMans180SX's Avatar
how about Mobil1 Ow-40? low winter weight, with high film strength, it's the best. 3 quarts of that and a quart of 15w-50 and you have like 5w-45. It's the best all year round!
I would never run 20w-anything in my car, the wear on startup is too great.
Old 02-03-2007, 04:09 PM   #14
EJ253
EJ253's Avatar
i need to read up on oil weights again. i forgot most of it all.
Secret Society
