Old 02-05-2002, 01:28 PM   #1
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
i am, as i have said for a while now, looking to buy 2 cars, one with hella lots of miles, one with slightly fwer and a 5 speed
but, if i want to up compression to squeeze some more horses out of the KA (dohc), what kind of numbers should i look for, i want a relaible daily driver, so i am thinking about going compression pistons and rings with forged arms...
what are your thoughts on overboring?
and what kind of prices should i be looking at?
any help is greatly appreciated
Sean
oh... would i need to upgrade cams?
SaintlyCharBoy is offline   Reply With Quote
Old 02-05-2002, 03:50 PM   #2
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
I would not recommend boring out the 240.  The cylinder walls a Very skinny as is.  Hopwever I seen people bore it out to like 2.440 liters.
Miles on the KA block don't really matter seeing as it is Iron, and pretty much bullet proof from the factory.  You will want to replace the crack, pistons, rods, etc. If it's miles are too high.  For the reliable High compression engine, everything should be forged.
As for upgraded Cams.  PDM makes some and so does Jim Wolf Technologies.  Nismo too.  (nismo's is just two 91' exhaust cams.  one repinned to fit the intake side)  I've heard the JWT's are nice because there is almost no low end torque loss and they are made from blanks, whereas you get more HP on the top end with the PDM's, but loss of low end torque, and they are re-grinds.
Depending on how much work you wanna do, you can get around 250 hp out of an NA 240 with about 7-10k from what I hear.  That includes EVERYHTING.  Sorry I can't be more specific.
sykikchimp is offline   Reply With Quote
Old 02-05-2002, 04:20 PM   #3
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
A cheap alternative to running higher compression is to get your 5-Speed DOHC and swap in some pistons from a SOHC into your car. It will increase it to 10.5.1(could be wrong) and give about a 5% gain. Not alot but its alot ezier and cheaper and if you run higher compression then that on the street then have fun stopping and going out of the way for 103 octane gas every time you need gas. Its just not very practical for a daily driver. Even with the higher compression I would run a higher octane like 95, and in states like mine that is hard to find. You will have to stock up on octane booster for when you fill up.
West is offline   Reply With Quote
Old 02-05-2002, 04:42 PM   #4
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Don't bore out the engine, it will screw with your cooling system, something you don't want in a daily driver. Compression all depends on what you want to put into the car. 10.0 to 1, give or take, is about as high as you'd want to go to prevent detonation on pump gas, go much higher and you'll need to use additives to increase the octane level. If you're increasing compression, you'd prolly want to combine that with new cams. Add on top of that your intake, headers, exhaust, and an ecu reprogramming, and you will prolly have some decent performance.
misnomer is offline   Reply With Quote
Old 02-05-2002, 04:51 PM   #5
wherezmytofu
wherezmytofu is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from misnomer on 4:42 pm on Feb. 5, 2002
Don't bore out the engine, it will screw with your cooling system, something you don't want in a daily driver. Compression all depends on what you want to put into the car. 10.0 to 1, give or take, is about as high as you'd want to go to prevent detonation on pump gas, go much higher and you'll need to use additives to increase the octane level. If you're increasing compression, you'd prolly want to combine that with new cams. Add on top of that your intake, headers, exhaust, and an ecu reprogramming, and you will prolly have some decent performance.</td></tr></table><span id='postcolor'>
arg!!!!!!!! im sick of this...i's 12.5: 1 on 93 octane, the nsx is 10.6:1 and runs on 93 octane....look at the new rsx ......11.5 stock............
wherezmytofu is offline   Reply With Quote
Old 02-05-2002, 04:55 PM   #6
wherezmytofu
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from WeST on 4:20 pm on Feb. 5, 2002
i dun want 2 go against a mod but.........are you sure that you can take pistons off a soch and put it in a doch because the soch is 3 valves per cylinder and the doch is 4 valves per cylinder, the valve relief on the soch pistons should be different then the doch pistons...so the exhuast valves would line up and will hit.......
edit: west bought the idea that ka pistons are not domed....if thats true then there is no problem <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=':D'>
(Edited by wherezmytofu at 5<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>8 pm on Feb. 5, 2002)
Old 02-05-2002, 05:01 PM   #7
misnomer
misnomer's Avatar
Tofu: I was simply going off what my auto tech instructor mentioned. He has an old Pontiac that runs on 10.5:1 compression, and it detonates when he gets down to lower altitudes.
Old 02-05-2002, 05:04 PM   #8
wherezmytofu
i know four itr the run stock except for 12.5 on 93 octane...also nsx,itr, s2k, rsx, have &gt;10.1:1 stock i guess the timing is just different
(Edited by wherezmytofu at 5<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>6 pm on Feb. 5, 2002)
Old 02-05-2002, 05:13 PM   #9
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from wherezmytofu on 5:55 pm on Feb. 5, 2002
i've heard of it being done before. you have to grind down the tops of the pistons to get the 10.5:1 compression
whateverjames is offline   Reply With Quote
Old 02-05-2002, 06:58 PM   #10
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
i was talking to &nbsp;my friend about the 10.5:1 and i was wondering what he thinks, he told me that the new celica runs 11.5 (not very sure), so i'd assume it'll be fine
240meowth is offline   Reply With Quote
Old 02-05-2002, 09:43 PM   #11
White240sx
White240sx is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from SaintlyCharBoy on 1:28 pm on Feb. 5, 2002
Sean</td></tr></table><span id='postcolor'>
Give Rebello Racing a call. They build N/A KA's and talking to them will be more enlightening than trying to get answers on a forum.
*BTW: I would recommend calling them only if you are serious about buying (willing to spend around $3000 or more). I wouldn't figure that they would be opposed to answering questions, but I’m fairly certain they stay busy over there so make it worth their time. I don't mean to sound gruff, but do you know what I’m saying?
White240sx is offline   Reply With Quote
Old 02-06-2002, 02:54 PM   #12
sykikchimp
WOW addicted
sykikchimp's Avatar
those car can run those compression rations on 93 octane b/c the have much different MAF's, and Fuel systems, and timing, and cams, different head designs, etc. &nbsp;Without modifying the Fuel and air management in the car, (and several other factors) you WILL experience detonate with higher comp. pistons. &nbsp;Thats why it's a lot more work than just throwing in different compression pistons. &nbsp;
I know thats not any help, but I don't want you to leave thinking this is a simple as buying new pistons, cracking open the engine, and poping in new pistons
Old 02-06-2002, 03:48 PM   #13
geeaj
geeaj is an unknown quantity at this point
I would have to agree with the last post. Just because a Toyota Celica is running high compression with 93 octane (compression higher then the 10.5:1 planned for the ka24 rebuild), doesn't mean jack.
The Toyota has different fuel mapping and air/fuel programming then our ECUs. I suspect that the algorithms used retard timing during certain scenarios so that detonation will not occur.
What this means is that the compression isn't static, it changes based on the variables such as throttle input, air temperature, etc.
You can very well run 10.5:1 compression on street gas and still run like shit, your car pingin' for dear life on WOT. It all depends on the fuel/air management.
Given your situation, give Rick at Rebello motors a call. This summer, I plan on having them build a N/A ka24e running high compression (but not as high as what you guys are thinking).
Another aspect to consider is using forged versus cast pistons. You can save the money on forged pistons and use the money for porting/polishing (only worthwhile if ka24e...ka24de head are siamesed together so there isn't much metal to begin with.) *thx dpro/dave for that tidbit of info*
If your are not going turbo, forged pistons ARE NOT NEEDED. The cons of forged vs cast for N/A applications, simply outway the pros.
For one, there is cost. That is self explanatory.
Forged pistons have a very different expansion rate vs cast pistons. What does this mean in real day to day driving? Your motor will be noisier, it will not be as smooth.
Do yourself a favor and give the Rebello guys or Sunbelt motors a call.
geeaj is offline   Reply With Quote
