Old 01-30-2007, 08:53 AM   #1
nevaland9
nevaland9's Avatar
nevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfectionnevaland9 is close to perfection
Send a message via AIM to nevaland9
Has anyone tried the 4lug to 5lug adapter?
Has anyone tried this? its cheaper than the conversion, but is it reliable?
http://cgi.ebay.com/ebaymotors/VERY-...spagenameZWDVW
CEO @ Sticky Garage 516-993-7315 -Jason
Check out my warehouse!
nevaland9 is offline   Reply With Quote
Old 01-30-2007, 09:16 AM   #2
Rod
Rod's Avatar
Rod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enough
it's defiantely cheaper than the 5-lug hub conversion. I've been running 4-lug adapter spacers (25mm) for over a year now without any problems, in drifting and autocrossing. My only concern is the treading on the studs. You might wanna look into it, but I'm pretty sure those are not for nissans. I think nissans are 1.25 or something. check it out and good luck!
Rod
Rod is offline   Reply With Quote
Old 01-30-2007, 09:25 AM   #3
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
Well, if you're going to use them on an S13, these won't work because they're not 4 x 114.3. To be honest, I wouldn't go for these for a couple reasons.
1) they're very thick, and most good looking, 5-lug wheels have low offsets. Put that together and you're going to have a wheel track so wide you'd need overfenders on top of overfenders to make them fit.
2) The thickness also covers up the wheel hub, so your lugs will not only be holding the wheel on, but also supporting the weight of the car. (Not a good thing). If you notice on the Ichiba wheel spacers, the thicker ones have a machined-in step, which essentially extends the hub, so your wheel is supported.
But, if you're building a show car, or a really light-duty backup car, then these will be ok.
edit: 240Trainee got in there while i was typing my reply
S13 Charlie is offline   Reply With Quote
Old 01-30-2007, 10:28 AM   #4
yrk323
yrk323 can only hope to improve
ive seen these break more than once. they are pretty unbalanced left to right. wheels come off, studs break etc. also that would just suck to run high offset wheels just because they are 5 lug. if you want cheap 5 lug, bolt a 5 lug rotor to your 4 lug hub and drill the 5 lug pattern into the hub, and press studs in.
yrk323 is offline   Reply With Quote
Old 01-30-2007, 10:39 AM   #5
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
Ive had the 5 lug wheel adapters for more than a year and I beat the shit out of the car drifting and they still are holing up. I had to have the fenders pulled though because my tires were rubbing.
s13 drifta is offline   Reply With Quote
Old 01-30-2007, 09:25 AM   #6
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Those won't work for a 240, stock bolt pattern is 4x4.5/ 4x114.3, not 4x100 or 4x108
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 01-30-2007, 03:10 PM   #7
ayuaddict
ayuaddict's Avatar
"AND WILL ALSO ADJUST YOUR OFFSET HIGHER."
uhhh huh. looks like trash...
try dna or gto or something.
Old 01-30-2007, 03:52 PM   #8
backroadtouge
backroadtouge's Avatar
backroadtouge is a jewel in the roughbackroadtouge is a jewel in the roughbackroadtouge is a jewel in the roughbackroadtouge is a jewel in the roughbackroadtouge is a jewel in the roughbackroadtouge is a jewel in the roughbackroadtouge is a jewel in the rough
basically, if it puts your life in its hands (or bolts), dont buy it off ebay.
お金も腕も、何も無い・
backroadtouge is offline   Reply With Quote
Old 01-30-2007, 03:57 PM   #9
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
< directly at looked when you blind can LED HYPER-BRIGHT 5mm small bright very>
I'd buy based on that statement.
SochBAT is offline   Reply With Quote
Old 01-30-2007, 05:18 PM   #10
A Spec Products
A Spec Products's Avatar
You're already gonna spend almost $200 on spacers, but don't want to just save up $500 and get the real deal?
I'd save for 5 lug.
Do it right the first time.
A SPEC PRODUCTS CORP
Old 01-30-2007, 05:27 PM   #11
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
Originally Posted by A Spec Products
I'd save for 5 lug.
Yeah, what he said
ripnbst is offline   Reply With Quote
Old 01-30-2007, 05:25 PM   #12
nevaland9
nevaland9's Avatar
thanks everyone, im not sure if im goan do them yet but if i am i wasnt planning on using those e-bay ones i just couldnt find a good site to put up so i used e-bay..yea those look like crap..
to the guys that have been using them over a year: do you remember where you got yours from and what brand they are? i think H&R makes them if im correct but id rather use the ones you guys used. Does it tell you what torque spec to use or u just go by nissan torque specs?
thanks for all you feedback i think im gona go for it, ill let you guys know how it goes
