Old 01-31-2007, 11:50 PM   #1
tamdo7114
tamdo7114 is an unknown quantity at this point
battery died
the other day i was at work, got off started my car and it didn't. thought it was my lights and i forgot to leave the on. jumped my car ran fine. next day went out and started but this time the battery was completely dead. the digital clock was not even on. i was thinking it was the alternator but after thinking shouldn't the battery light go on? please your input would be nice.
tamdo7114 is offline   Reply With Quote
Old 02-01-2007, 12:23 AM   #2
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
bring your battery to autozone and ask them to slow charge your battery
That should solve the problem. If not your battery is gone.
TAMTANIUM is offline   Reply With Quote
Old 02-01-2007, 12:27 AM   #3
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Your battery is either old or your alternator is shot.
You can take your battery and alternator to autozone/pepboys to get it tested.
Not sure on the battery light.
Jung918 is offline   Reply With Quote
Old 02-01-2007, 12:32 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
The battery light is a low voltage light. Yeah, it should have come on if you're below 12.5V I believe. If you jumped the car and it didn't charge the battery, it's probably your alternator (you'll find out if you battery checks out at Autozone). If the batt is OK, put a voltmeter on the batt terminals while the car's running - should be getting 13.5V or so. If not, your alt is bad. If you are, then you've got some serious power draw (fuel pump most likely) and should PM me cause I'm tired of typing what-ifs lol.
Old 02-01-2007, 01:37 AM   #5
tamdo7114
the battery is new, just recently bought one. so i'm guessing it's the alternator. i'll have it checked out tomorrow. thanks for the input guys. also i changed out the fuel pump about a month ago. so maybe power draw.
Old 02-01-2007, 01:59 AM   #6
Jung918
Jung918's Avatar
It shouldn't matter unless it is grounded out and kept running while the car was shut off. It's most probally a bad alternator. There is a write up on using a quest alternator.
Old 02-01-2007, 02:47 PM   #7
GSXRJJordan
That's what happens sometimes. Relays are activated by a switched ground, not a switched +12V, so sometimes they get grounded and keep the pump/fans/ac comp/lights/whatever on, and with a stock fuel pump, you can't hear it. Anyhow, if it's your alt, you've got a lot of options (stock KA, rebuilt/Autozone, rebuilt/Alt shop, Quest, etc).
Old 02-01-2007, 03:12 PM   #8
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
same thing happened to me...but..
this is what i did.
u should take off the terminals then check the wires the see if theres any corrosion. i took all mine off and all the wires were blue with that acid crap.
put everything back and it started.
s13gold is offline   Reply With Quote
Old 02-01-2007, 03:12 PM   #9
s13gold
s13gold's Avatar
Trader Rating: (79)
you have to take it off...you cant see it without...mine looked fine until i took off the terminals.
