Old 02-11-2007, 06:17 PM   #1
clutch kick drifter
clutch kick drifter's Avatar
clutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura about
Blow off valve , welding it on.?
Now i got it welded on....theres a main vacum line for the line that comes off the TB and then a small nipple in the back? Where does that go to....cuz right now its got nothing on it adn im just getting surge and when it does go off its very faint.
I got my greddy type S in today and on the flange there is a orange seal. Does anyone know if that is supposed to be used somehow. All i can think of is cut a hole in my hotpipe and weld on the flange and as long as i get my welds good with no holes i should be good riht? sorry guys, maby im stupid but this is the frist time ive gotten a fmic/bov kit so gimme a break!
clutch kick drifter is offline   Reply With Quote
Old 02-11-2007, 06:36 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
I dont know what you mean about an orange seal (the only Greddy BOV I've installed is a RS for an Evo, and it was a kit specifically for the Evo) - if your hotpipe doesn't have a flange, you'll need to take it to a shop and have them weld a flange on. My Greddy hotpipe didn't have one, but it takes all of 10 minutes to cut the flange off my old hotpipe/hole-saw-bit a new hole in the Greddy hotpipe/weld the old flange on there. Do yourself a favor and blow out all the little metal shavings before welding the new flange.
Old 02-11-2007, 09:03 PM   #3
clutch kick drifter
no one, im needing toknow by tommorow!
Old 02-11-2007, 09:14 PM   #4
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
Take the o-ring off, use a hole saw, 1" or something, whatever matches the flange, and dirll a hole in your IC piping so the flange will sit in it, weld around it. Simple...
240silvia is offline   Reply With Quote
Old 02-11-2007, 09:28 PM   #5
clutch kick drifter
Ok , what i was thinking but the o-ring had me puzzled. Common sense is not my speacilty LOL thanks 240silvia!
Old 02-11-2007, 10:09 PM   #6
240silvia
240silvia's Avatar
no problem man, thanks for the positive rep, give me some more when you can!!!! I need it, lol!
Old 02-12-2007, 12:50 AM   #7
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
http://storesense.megawebservers.com...ipe/Detail.bok
can't go wrong for $120
Ca_laurier is offline   Reply With Quote
Old 02-12-2007, 07:28 AM   #8
clutch kick drifter
Yeah ^ I just dont have the money so im making my own. !
Old 02-14-2007, 07:18 PM   #9
clutch kick drifter
^ read the top. ive got another problem but just didnt wanna start a nwe thread.
Old 02-14-2007, 08:31 PM   #10
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
I believe that o-ring goes between the flang and bov. These type-s bov has dual springs. If your car doesn't have horse power higher than 300whp, then just take it apart and remove the smaller spring. I've done this for evo and srt4 plenty of times. Use the top nipple for the vac, leave the middle nipple alone. that's just a secondary source to open the bov earlier/stronger.
driftingisgay.com
nrg is offline   Reply With Quote
Old 02-14-2007, 08:41 PM   #11
clutch kick drifter
i got around 390 so im good on that aspect. The thing thats hard to explain is like its so quiet? It dosent evens eem normal.....hmm
