Old 02-13-2007, 09:13 AM   #1
OmaplataS14
OmaplataS14's Avatar
OmaplataS14 is a well-known jackass
s14 Stability issues...
Ok ... another probably dumb question,
when driving at around 50 -70MPH when the road has some very slight rough spots (small bumps in the road) You car shouldn't get loose should it? I mean it almost feels almost like your hydroplaning. This is obviously not a good thing, but this is the issue I am getting, does anyone know what could be causing this? I am planning on taking it to a shop, but would like to know some possible causes.
Any help is highly appreciated.
OmaplataS14 is offline   Reply With Quote
Old 02-13-2007, 09:39 AM   #2
SeattleSR20
SeattleSR20 is an unknown quantity at this point
I had this feeling once before, but it turned out to just be low tire pressure for me...damn cold weather. I would start by checking that, also your rubber subframe bushings could be shot and might need replacing.
SeattleSR20 is offline   Reply With Quote
Old 02-13-2007, 09:46 AM   #3
projectRDM
projectRDM's Avatar
Blown shocks
Low tire pressure
Poor alignment
Damaged suspension components
Old 02-13-2007, 10:25 AM   #4
BC240
BC240's Avatar
BC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enough
Filling up my tires fixed this issue for me. You can lose a lot of pressure over the winter
BC240 is offline   Reply With Quote
Old 02-13-2007, 08:47 PM   #5
OmaplataS14
Thanks guys, I will check these things.
Old 02-13-2007, 08:55 PM   #6
SC_S13
SC_S13's Avatar
SC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to allSC_S13 is a name known to all
have the mechanics check out your alignment while their at it....and then make it a habit to check your pressure!
SC_S13 is offline   Reply With Quote
