Old 02-13-2007, 08:59 PM   #1
itsmeviet
itsmeviet is an unknown quantity at this point
Lock nuts for MR inner/outer ties?
I went to go get my megan racing inner and outer tie rods installed at hiro's. They said they think that these are suppose to come with lock nuts, where the inner and outer tie rods connect. Has anyone bought MR tie rods before and know if they come with these lock nuts? thanks
itsmeviet is offline   Reply With Quote
Old 02-13-2007, 09:44 PM   #2
John_R
John_R is making a name for him/her selfJohn_R is making a name for him/her self
Lock plates or Lock nuts?
No they do NOT come with new lock plates. (the little plate that locks the rack to your tie rod) Yes, they do come with lock nuts. There is one nut on each side of the blue outer tie rod. You should get one nut with your inner tie rod, and one nut with your outer tie rod.
If this didn't answer your question, I can even take pictures if you like.
John
John_R is offline   Reply With Quote
Old 02-13-2007, 09:50 PM   #3
loosesocksdiff
loosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of lightloosesocksdiff is a glorious beacon of light
Yes it supposed to come with it. But I think you can use the stock ones.
loosesocksdiff is offline   Reply With Quote
Old 02-13-2007, 11:48 PM   #4
itsmeviet
Well heres a pic of them, this is pretty much what I got. Are the lock nuts shown in any of these pics?
http://www.frsport.com/images/detail...g_MR6255_1.jpg
http://www.frsport.com/images/detail...219_1_2338.jpg
Old 02-14-2007, 03:30 PM   #5
John_R
Yes, Look at the Outer Tie End. See the blue part, there is one nut in front of that. You should get a 2nd one with your tie rod. (thats how mine was packed)
Its just a 14mm nut (i think). Just take the one off your outer tie rod, go to Ace hardware, and buy another. Probably .25 each.
Old 02-14-2007, 04:14 PM   #6
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
you use your stock lock nuts. the lock plate on the inner tie rod wont work (if you use spacers), you're supposd to use locktie
driftingisgay.com
nrg is offline   Reply With Quote
