Old 02-02-2002, 11:24 PM   #1
Red
Red's Avatar
Red is an unknown quantity at this point
Sup All
If I could get some info on the MAX Wheel/Tire combo I can have without my wheel's rubbing
I see alot of 235-40-18 (front) and 265-40-18 (rear) tires on on the web for our 240's
Red is offline   Reply With Quote
Old 02-02-2002, 11:35 PM   #2
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
235's in the front may rub without spacers and 265 will rub in the back without spacers
Nismos14 is offline   Reply With Quote
Old 02-02-2002, 11:45 PM   #3
White240sx
White240sx is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Nismos14 on 11:35 pm on Feb. 2, 2002
235's in the front may rub without spacers and 265 will rub in the back without spacers</td></tr></table><span id='postcolor'>
Depends on the car and offset. S13's won't support those widths without flares. I've seen numerous S14's with those widths, no flares. Of course if HA coilovers are run you bite into width as well, so it depends on the set-up.
White240sx is offline   Reply With Quote
Old 02-03-2002, 12:23 AM   #4
Red
Red's Avatar
<a href="http://www.executivecleancar.com/240/
17" target="_blank">http://www.executivecleancar.com/240/
17</a> by 8 in front (off-set is +38)
17 by 9's (off-set is +42) in the rear.
235/45/17 in front
255/40/17 in the rear
No spacers mentiond
Also from <a href="http://www.sportcompactcarweb.com/index.jsp
18x8.5" target="_blank">http://www.sportcompactcarweb.com/index.jsp
18x8.5</a> front
18x9.5 rear
235/40/18 front
265/35/18s in back
No offset mentiond but i'm sure there is some.
And another
235/35-18 front
255/35-18 back
No idea on wheals not mentiond
More
19x8.5 front
19x9.5 rear
235/35/19 front
265/30/19 rear
another with not enough detail
______________________
What is off-set anyways i'm kinda lame when it comes to Wheels and Tires.
Old 02-04-2002, 08:41 PM   #5
240racer
240racer's Avatar
240racer is an unknown quantity at this point
you can search zilvia for offset stuff otherwise go to tirerack and look at their stuff
http://www.tirerack.com/wheels/tech/offset.htm
also, 19s seem real big for the 240, so it kinda depends on if you are going for the big wheel look (which is fine) or pure performance. &nbsp;I'd stick with 16-18&quot; wheels for this tire outside diameter. &nbsp;Also, most people seem to like what they have and 16-18 is most common.
Adam
240racer is offline   Reply With Quote
Old 02-04-2002, 10:22 PM   #6
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
since we are on the topic. &nbsp;wil 17x7 or 17x8 fit my s13 w/o spacers? &nbsp;i'm thinking about either getting 17x7 or 17x8 or 16x7, but i don't know which is the best choice
240meowth is offline   Reply With Quote
Old 02-04-2002, 11:19 PM   #7
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
all of those should fit with the right offset.
AJ is offline   Reply With Quote
Old 02-05-2002, 12:19 AM   #8
tnord
tnord's Avatar
tnord is an unknown quantity at this point
why do you want such huge wheels? it'll just make you slower
tnord is offline   Reply With Quote
