Old 02-18-2007, 01:22 PM   #1
BLITZZZ
BLITZZZ is making his/her stupidity well-knownBLITZZZ is making his/her stupidity well-knownBLITZZZ is making his/her stupidity well-knownBLITZZZ is making his/her stupidity well-knownBLITZZZ is making his/her stupidity well-known
Boost spike, actuator problem?
Hey, to make a long story short:
1) I welded a hks ssqv bov flange on my hotpipe, for some odd reason the flange was warped, and with the bov on it would leak.
2) The turbo made a sharp whistle noise, i removed the flange, welded a steel sheet over the hole to cover it up temporarily.
3) the turbo still makes a whistling noise ( it didnt beforehand) and the boost spikes to 10.0 ~ 10.8 lbs (STOCK SR20DET REDTOP)
4) I disconnected my greddy profec, and it still spikes to 10lbs. (The car used to be a consistent 7lbs)
The temperature here is and has been about 15-25 degrees Fahrenheit. Other than the boost spike and whistle the car runs fine.
Could the weather be to blame for
a) dramatic 3.8lb increase in boost
b) sharp whistling noise
or could something be wrong with my actuator? (my turbo is fine, atleast the blades/seals are)
-Sorry to make such a big deal about this, just wanted to be thorough.
BLITZZZ is offline   Reply With Quote
Old 02-18-2007, 01:27 PM   #2
NemeGuero
No more nissan.
NemeGuero's Avatar
check vac line to actuator.
Old 02-18-2007, 01:37 PM   #3
BLITZZZ
I did, it was cracked a little from being stretched over the nipple, so i replaced it with a bigger diameter new line, still same ole problem..
Old 02-18-2007, 02:59 PM   #4
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
i maybe the sound your hearing is compressor surge since the bov wasnt seating properly, and now that you've just completly covered the hole on the hotpipe, it is just surging the compressor. If you want we could meet up somewhere and i could check it out for you man. PM me for my cell number
Slip Gypsies Blog
not sure if you realize this
Old 02-18-2007, 03:03 PM   #5
BLITZZZ
im not in the state right now thanks, anyways, i know what compressor surge is. this is when I'm in boost it whistles, and the real problem is just that turbo / wastgate is spiking
Old 02-18-2007, 03:26 PM   #6
S14DB
AFC #1
S14DB's Avatar
Check the vacuum actuator and it's linkages.
Old 02-18-2007, 03:29 PM   #7
punxva
punxva's Avatar
Trader Rating: (31)
hmm sounds like maybe a boost leak somewere too, check your piping, and by whistles do you mean it sounds like its just spooling very loudly?
Slip Gypsies Blog
Old 02-20-2007, 12:09 PM   #8
BLITZZZ
just checked all piping for leaks, retightened everything, still does it, the car runs perfect its just boosting to 10lbs as opposed to 7 and whistling like a bitch, i'm going to replace the actuator this weekend, hopefully that will fix it..
question.. if a bolt on the Intake manifold was removed for sometimes and my car goes through hot and cold cycles could the flange have warped? or would there have to be like 2 or 3 bolts missing? (all other nuts/bolts were tight to spec)
thanks
Old 02-20-2007, 12:58 PM   #9
S14DB
AFC #1
S14DB's Avatar
More like the welder sucked and warped the flange.
Old 02-20-2007, 08:28 PM   #10
BLITZZZ
your butt.... on my....... butt..
uhhhh heh heh heh
Old 02-22-2007, 01:01 PM   #11
BLITZZZ
solution:
driving today and pop, intercooler pipe blows off, t-bolt clamp broke in two, im guessing it was already pretty much done for and wasnt sealing a coupler correctly.. went to Napa got a ring clamp and fixed the whistle, and the boost dropped down to 8.9-9.5 PSI, fuckin weird
Old 02-22-2007, 11:15 PM   #12
Ameer
Ameer is making a name for him/her selfAmeer is making a name for him/her self
are you running a stock actuator?
Ameer is offline   Reply With Quote
Old 02-22-2007, 11:31 PM   #13
punxva
punxva's Avatar
Trader Rating: (31)
wooohooo i knew it had to do with a coupler, lol congrats man
Slip Gypsies Blog
