Old 02-19-2007, 01:16 AM   #1
hellllo
hellllo can only hope to improve
E-brake problem
Tried search found nothing. I'm a car beginner coming from doing computers. Well its too cold here right now to work on it but i just want to see what i'm looking at.
The e-brake handle has like nothing in it, it pulls but doesn't stay up, i also hear no clicks of it pulling or anything, the e-brake button is also pressed in the whole time. I can make the e-brake handle work but its really weird. I have to pull the button out at the same time as a i pull the e-brake. Sometimes it works partially so i have to do it over and over until i hear the hard clicks so the car won't roll down.
What is the problem?
Sorry for asking such a newb question, its so cold here i cannot work on it but i want to see what i'm looking at here.
Thanks
hellllo is offline   Reply With Quote
Old 02-19-2007, 01:41 AM   #2
hellllo
bump anyone =[
Old 02-19-2007, 01:47 AM   #3
oscar
oscar is an unknown quantity at this point
get a drift button. thats what i have it works good. its a lil button that drifters use to easily move the hand brake up and down.
oscar is offline   Reply With Quote
Old 02-19-2007, 01:48 AM   #4
hondasrboring
hondasrboring is an unknown quantity at this point
Take it apart and find out why your button is not *SPRINGING* back out like it should.
hondasrboring is offline   Reply With Quote
Old 02-19-2007, 02:28 AM   #5
Sidewayzzz
Sidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura aboutSidewayzzz has a spectacular aura about
Send a message via AIM to Sidewayzzz
Someone popped out the tabs that hold the spring against the button to keep tension on it, buy a drift knob or deal with it....
Better yet, go use the fucking thing like it should be, just pull it at 45, clocked sideways...you'll see why people do that when you try to counter-steer with the quickness and you'll be damn glad your e-brake isn't stuck up.
Sidewayzzz is offline   Reply With Quote
Old 02-19-2007, 02:33 AM   #6
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Like sidewayzzz said, there are two little tabs under the ebrake handle cover, if you slide the cover off, then use a screw driver to slide the spring up towards the end of the handle and then bend the tabs in under the spring, you'll have yourself a locking e brake. However, if your spring is gone, like you said, you just have to pull the button out when ever you set your ebrake. I was to cheap to but a drift button so I opened the tabs up. I also slid my ebrake cover down a bit so I could reach the button when I need to park.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 02-19-2007, 02:36 AM   #7
Unit-121
Unit-121's Avatar
Unit-121 is an unknown quantity at this point
If I were u I take that shit apart buy one from a use 240 and put that shit in . But thats Just Me
Unit-121 is offline   Reply With Quote
Old 02-19-2007, 08:20 AM   #8
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
i would just pull off the boot and check those tabs first, and if that is the case, then just either buy or make a drift button, since it would probably end up being cheaper than going to a junkyard
Slip Gypsies Blog
not sure if you realize this
Old 02-19-2007, 11:55 AM   #9
!Zar!
!Zar!'s Avatar
Sounds like someone bent the tabs so the spring wouldn't push the button back.
That way they could,"drift".
Look around on ebay for a, "drift knob or drift button". That'll make it easier than trying to use your fingernails to pull the button out.
Old 02-19-2007, 01:52 PM   #10
hellllo
well i looked up the "drift button" on ebay, and thats what the car has, it covers the oem button which is already pressed down. i bought the car modded so im guessin this is normal.
but question is how does it make drifting more easier or effecient if u have to pull the drift button out to make it click? sounds dangerous to me ;x
Old 02-19-2007, 02:02 PM   #11
Sidewayzzz
um, when your sliding you want to snap the e-brake, let go and not worry about it staying up so you can counter-steer....
Old 02-19-2007, 02:06 PM   #12
hellllo
ahh makes sense thanks alot all for teachin moi =)
Old 02-19-2007, 02:52 PM   #13
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
you can get em at kragen or autozone or something. they are dirt cheap. once you put it on the e-brake, it fucks up the little spring and you'll always have to have it on there.
smurfgcr is offline   Reply With Quote
Old 02-19-2007, 03:13 PM   #14
!Zar!
!Zar!'s Avatar
Not really. Solely placing them on the ebrake doesn't do anything. You need to remove the spring yourself. THEN it will work as it should.
You don't always have to do anything. If you want to fix it you bring the spring back up and ben the tabs back to the original location.
Old 02-19-2007, 06:38 PM   #15
smurfgcr
my bad, thanks for the correction.
