Old 02-22-2007, 03:56 PM   #1
gun240metal
gun240metal is a jewel in the roughgun240metal is a jewel in the roughgun240metal is a jewel in the roughgun240metal is a jewel in the roughgun240metal is a jewel in the roughgun240metal is a jewel in the roughgun240metal is a jewel in the rough
Fpr question
i'm putting a nismo FPR and a jegs pressure gauge into a redtop. Will I need any other hardware as far as fittings and such.thanks
gun240metal is offline   Reply With Quote
Old 02-22-2007, 04:25 PM   #2
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
what kind of fpr? type a or b? type a is the kind with rubber hose fitting and should be a direct replacement for your factory fpr. type b is also a rubber hose fitting but can be mounted anywhere and you need a special fitting to replace the stock fpr. what does you jegs gauge have an input for rubber or an? pics would be helpful btw....
DoriftoPnoy is offline   Reply With Quote
Old 02-22-2007, 05:11 PM   #3
defiantmofo
defiantmofo is a well-known jackass
just so you know, i bought a type a and it didnt fit well in the red top with greddy intake. With the nut all the way in, max or min pressure(not sure) it fits, but as soon as you try to adjust it, it hits the valve cover(with greddy intake). not sure what you have, just a heads up.
defiantmofo is offline   Reply With Quote
Old 02-23-2007, 02:32 PM   #4
gun240metal
I have a type A and the gauge is AN fitting.
