![]() Join Date: Sep 2005
Cant Remove Ball Joint???
im trying to complete my 5lug swap here and this stupid ball joint is in the way. im not sure if im missing something. all the write ups ive seen dont mention anything about or say use a hammer to knock it. tried using the hammer and i get nothing....
any suggestions of how to get this shit out? ![]() |
#2 | |
![]() Join Date: Nov 2006
Why again are you trying to get it out? Either a shop press or a BFH (big friggin hammer). my contol arm ball joints came out with some heat and a BFH
![]() $pending dead pre$ident$ J@CK@TT@CK! |
![]() Join Date: Dec 2004
Just use a hammer, and hit the knuckle thats holdin it on a few good times. Make sure you have the nut on the end, just incase you suck, and you miss. No one likes mushroomed ends.
CliffNotes: Bang the fuck outta the knuckle. |
WOW just wow thats not a ball joint that is your tie rod end, and if its torn get new ones cause they arent supposed to come out if thats what u meant, if not and u are just trying to get it off the knuckle just beat the shit out of the knucle right near it
#5 | |
you are retarded. a tie rod end is a ball joint. its just a specific name for that ball joint you are suppose to get it out with a ball joint puller it wedges on beneath the steering knuckle and theres a bolt ontop that you turn on that pushes on the top of the ball joint, which pops it out of the knuckle. dont be a retard like all these other guys, use the proper tool for the job, dont micky mouse it like all these retards are telling you to do. |
#6 |
#8 | |
#11 |
![]() Join Date: Mar 2006
hit it hard as fuck with the bolt off from the top with a mallet/hammer. itll do it. or if you wish leave the nut on threaded like a few turns. its super easy just hit it hard.,
driftparty.com |
#13 |
![]() Join Date: Dec 2002
Pickle forks tear the boot to hell, ruining the joint.
Hammering from the top crowns the top of the stud, ruining the joint. Use a proper removal tool, or hit the spindle to induce shock to loosen it, but odds are it's not going to be enough. |
#14 | |
Just be sure to get a one piece pickle fork - some of them have a head welded on to a handle, and you can break the welds with some good hammering. Been there, done that. However, if you need to reuse that tie rod end, a good screw-type puller is definitely the way to go. That'll pop the rod out without damaging anything. |
#16 |
Remove the cotter pin
uncrew the nut completly add some penetrating oil Put the nut back, with crown facing down just a couple of threads Hit the nut as hard as you can When reinstalling, add some antiseize. Do NOT HEAT or hammer the rod itself |
