Old 02-22-2007, 08:28 PM   #1
FRpilot
FRpilot's Avatar
s13 blacktop/redtop maf interchangable?
are s13 blacktop and redtop maf interchangeable? i know ka sohc maf can be used in place of s13 sr maf but it has to be repinned/spliced. how about blacktop and redtop mafs? the same?
FRpilot is offline   Reply With Quote
Old 02-22-2007, 09:41 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
repinned/spliced? I'm using a single cam maf, was no big deal to get it plugged in. I believe all the SR MAFS are the same (S13/S14/S15), but I'm sure that the S13 ones are interchangeable.
Old 02-23-2007, 12:12 AM   #3
FRpilot
FRpilot's Avatar
hmm i thought some wires had to be flipped around or some minor modification was needed. thats strange..
i need a definite answer and no results in search.. but thinking about that.. a maf is a maf right? if z32 can be used with just some wire splice why can't an s13 blacktop and redtop work? i know the wiring harness is different, but should bolt up even if minor splicing to the maf plug is needed.
Old 02-23-2007, 12:20 AM   #4
Ameer
Ameer is making a name for him/her selfAmeer is making a name for him/her self
They are interchangeable. I put a blacktop maf on a redtop and worked fine. Im sure it would work viceversa.
Ameer is offline   Reply With Quote
Old 02-23-2007, 12:54 AM   #5
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
s14/s15 sr maf read different than the s13 maf's if i recall the later model blacktop has a different plug
sblack13 is offline   Reply With Quote
