stock thermo switch ground question
I'm making a new air condenser fan circuit with relay kit I bought from ebay.
I would like to use stock thermo switch (that is attached into lower coolant hose) with this relay kit. However this kit has one wire for the stock thermo switch while stock thermo switch has two wires. If I ground this stock thermo switch and hook it upto the relay, will it still work for the air condenser fan? |
![]() Join Date: Apr 2004
Oh boy. You need a fan controller.
The thermo switch has 2 wires because it measures resistance as a function of temperature change. The fan has 1 wire because it needs to see 12V (+) to draw power. A relay triggers a large current when it sees a small current. How can the thermo switch possibly trigger a relay when the thermo switch doesn't have current flowing through out? http://www.frsport.com/DIF_Dual_Fan_...40SX_t_22.html |
Thanks for the advice. One more question.
I have seen this relay kit on a friend's car. ![]() When you see this close, you will notice that the thermo switch has single wire and is grounded by the fitting. My ebay kit is same set up as this. I wanted a set up like this using the stock thermo switch. Is the Nissan thermostat with two wires totally different kind from the thermo switch in that picture so that grounding it to engine or chassis is totally impossible? If so, where can I get a thermo switch or sending unit that has same thread size as stock thermo switch? Last edited by jafero; 02-26-2007 at 08:34 AM.. |
#4 | |
You cannot remove the stock thermoswitch because the ECU needs to monitor coolant temperature. I have no idea what you want to do. The only options you have is either follow the link I posted above, or insert another thermoswitch for the fan controller somewhere else, preferably the upper radiator hose. Don't mess with your stock thermoswitch. |
#5 |
Sorry to confuse you.
I meant the thermo switch, not the thermostat. There are two thermoswitches in the car and the one located by the coolant bleeder hole monitors the water temp for the ecu, as far as I know. |
