Old 02-26-2007, 11:21 AM   #1
CrazyIvan
CrazyIvan's Avatar
CrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enough
S14 flooding
Hey guys, I bought a s14 w/ a blown motor, so I replaced the motor (kade to kade) and did a 5sp swap at the same time.
The motor is stock.
Stock AUTO ecu.
VSS in unplugged (wasnt able to find a s14 VSS yet).
I did all the wiring step by step exactly the same as the walkthroughs available for the 5sp swap, but now the car starts for a few seconds, idles very low (200 rpm maybe), and dies within seconds... I can start the car for a few times, but then it dies out and smells like fuel, so Im pretty sure its flooding the engine.
I've unplugged the MAF to see if it would make any difference, but it doesnt.
Checked vaccum lines, but they all seem ok.
What else should I check?
powder-coated.com - I do Custom Powder Coating
CrazyIvan is offline   Reply With Quote
Old 02-26-2007, 11:45 AM   #2
S14DB
AFC #1
S14DB's Avatar
Vacuum lines.
Old 02-26-2007, 11:53 AM   #3
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
If you keep giving it gas will it stay running?
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 02-26-2007, 12:47 PM   #4
aznpoopy
aznpoopy's Avatar
pull plugs and find which cylinder is flooding
make sure injector is not stuck open
make sure injector seals are not crapped out
to be honest i think the fuel smell is just you cranking it over too many times without it firing up
you sure you set timing properly?
check for vac leaks like db said as well.
aznpoopy is offline   Reply With Quote
Old 02-26-2007, 04:02 PM   #5
CrazyIvan
CrazyIvan's Avatar
If I touch the gas pedal it'll lower the rpms and the car wants to die...
Old 02-27-2007, 12:01 AM   #6
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
my car does the same thing. it smells like gas, causei keep tryint to start it but it doesnt. my dad told its the fuel pump, tom im goin to replace and c if it fires up. my vacum lines arent plug in either is that it does that.
grnappletree14 is offline   Reply With Quote
Old 02-27-2007, 02:23 AM   #7
drftwerks
what is timing at??
giantroboteyes.wordpress.com/
Old 02-27-2007, 05:15 AM   #8
gotta240
grnapples14- not sure what the hell you just said, but if you should plug your vaccume lines in before doing anything.... no vaccume lines=not running motor
Old 03-17-2007, 01:51 AM   #9
CrazyIvan
CrazyIvan's Avatar
well, took me a while but I finally had the chance to work on the car.
1st distributor was off by 1 tooth
2nd the worst gawddam vaccum line that could brake in the whole motor did, forking pain in the ass to get to it... here is the line, I got it off today and am getting it back together this weekend (maybe) if I dont get drunk on green beer
Old 03-17-2007, 02:13 AM   #10
S14DB
AFC #1
S14DB's Avatar
Replace the PCV while your at it.
