Old 07-28-2002, 02:16 AM   #1
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
i was told there was a recall on the 95-96 radiators cause if there was just a bit of air in there it would over heat.  i know this is true cause i just removed my fan clutch and now my car is over heating cause theres air.  can someone tell me the best way to remove the air.  i have ran the car with the bleed screw off for about 30mins, and i have also tried running the car with the rad cap off for the same amount of time.  any advice would be appreciated.  thx.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 07-28-2002, 10:35 AM   #2
95Blue240sx
no one knows how to bleed the cooling system???
Old 07-28-2002, 11:11 AM   #3
hopeful
hopeful is an unknown quantity at this point
turn the car on, let it run and when it starts to overheat the thermostat will open up and the coolant level in your radiator will drop. Fill it up, wait a bit fill it till it looks like it going anywhere and you should be done. I dont know if this is exactly correct can somebody correct me if I am wrong.
hopeful is offline   Reply With Quote
