I was wondering if the material was supposed to be so close to the rivets... If the pads wear even barely the rivets will score up my flywheel/pressure plate.
Im thinking of dremmeling the rivets down SLIGHTLY on the one side pictured above. The other side looks fine.
I was told the disc has around 10k on it
What do you guys think?
I was also wondering if you guys could tell me which side faces the flywheel? There is no indication on the disc... the side pictured is flat and the other side has a rasied area in the middle.
