Old 03-01-2007, 05:09 PM   #1
CSXTacy
CSXTacy's Avatar
CSXTacy has a little shameless behavior in the past
Exeddy Throw out bearing woes
ok i am installing my exeddy throw out bearing on to the sleve that goes into the transmission, the original one that came with the sr swap was cracked so i had to order a new one through nissan i ordered one for a 89 nissan 240sx and after trying to press on the bearing tonight i found that it slipped right on with little to no force. now the inner part of the bearing will spin on that sleve that it's pressed on to is this normal? i can remove the bearing from the sleve with my own 2 hands. did i order the right sleeve for the sr motor? any suggestions or tips would be greatly appreciated!! thank you for takin the time to read this.
CSXTacy is offline   Reply With Quote
Old 03-01-2007, 05:15 PM   #2
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
did you tell them that it was for an sr?
initial_drifter is offline   Reply With Quote
Old 03-01-2007, 05:31 PM   #3
CSXTacy
CSXTacy's Avatar
yes but they are a little slow around here they usually don't know what im talking about when i say swap a sr motor in so i had them print me off a picture from their diagrams of a 240 and the part looked right and once it came in i compaired them side by side and they look the exact same but i just don't know why the inner bearing spins on the actual sleeve
Old 03-02-2007, 07:40 AM   #4
CSXTacy
CSXTacy's Avatar
anyone??? please help!!!! will a ka 240 transmission throw out bearing sleeve work on a sr tranny? if not what type do i need? im so close to having my first running 240 please help!!!
Old 03-02-2007, 08:43 AM   #5
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
yeah it will, i've use it plenty of times, maybe the throw out bearing is the wrong one?
georgesal is offline   Reply With Quote
Old 03-02-2007, 10:16 AM   #6
CSXTacy
CSXTacy's Avatar
ehhh idk i purchased the exeddy stage 2 clutch kit specfically for my car idk if maybe the throw out bearing is wrong out of the box but is there any one that sells just the exeddy throwout bearing????
