Old 03-02-2007, 03:15 PM   #1
chr0nik_sm0k3
chr0nik_sm0k3's Avatar
chr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of lightchr0nik_sm0k3 is a glorious beacon of light
narps?
Originally Posted by Transman
Ive always been told to be careful when you buy a 240. You should always make sure that someone has installed the hardened narps. Not all narps are blow proof. you really dont want the narps to blow while bangin' gears. Ask me how i know.
A narp (short for "intake narp") is a valve under your intake that controls differential pressure and vacuum flow across your intake valve. It is critical that your narps be properly calibrated to your engine displacement. Nissan had a run of improperly calibrated narps that caused a cylinder reversion problem. Luckily they corrected that problem in 1993. There are still many Nissans out there with improperly sized narps.
Ask that guy Pauly Walnuts. I warned him about it, but he didn't believe me. He bought the teflon coated narps. I told him to get the hardened titanium ones. He didn't take my advice. His cylinder reversion was so pronounced that it caused his timing chain to break. He tried to save money and it cost him more in the long run.
Worst part about the teflon coated narps is that the teflon wears out over time. This causes the flow pattern around the narp to expand and cause cylinder reversion. There are few mechanics that truly understand narp function, much less diagnose it.
what do u guys think
chr0nik_sm0k3 is offline   Reply With Quote
Old 03-02-2007, 04:26 PM   #2
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
yeah, it's real, thank god i have a '95 and my narps are already properly sized. i'm thinking about upgrading mine when i get new muffler bearings.
cdlong is offline   Reply With Quote
Old 03-02-2007, 04:34 PM   #3
'90RPS13
'90RPS13's Avatar
'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute'90RPS13 has a reputation beyond repute
Send a message via AIM to '90RPS13
^~~~Holy Shit, Where'd ya find your muffler bearings? Mine just wore out the other day and the shits just not the same. Definately get back at me the 2nd tuesday of next week please.
'90RPS13 is offline   Reply With Quote
Old 03-02-2007, 04:38 PM   #4
locust13
locust13 will become famous soon enoughlocust13 will become famous soon enoughlocust13 will become famous soon enough
Send a message via AIM to locust13
i almost fell out of the chair after reading that....
locust13 is offline   Reply With Quote
Old 03-02-2007, 04:41 PM   #5
mrmephistopheles
mrmephistopheles's Avatar
Yeah this is a common first upgrade. I think I got my narps put in before I even got a differential flange warmer.
Originally Posted by PHLIP
Old 03-02-2007, 04:46 PM   #6
S14DB
AFC #1
S14DB's Avatar
I got mine here:
http://kalecoauto.com/index.php?main...products_id=10
Old 03-02-2007, 04:50 PM   #7
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
wow i gotta save up for thoes... i just spent all my money on my door handle clutches.. crap
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 03-02-2007, 05:06 PM   #8
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
I did that before I even changed my rad bearing... you don't want to risk having your narps fail.
mRclARK1 is offline   Reply With Quote
Old 03-02-2007, 05:15 PM   #9
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
ok ok so if i got gold plated narps im fuked?....darn ima go back and leave some negitive feed back i was told teh gold plated was teh best.
arkive43 is offline   Reply With Quote
Old 03-02-2007, 07:20 PM   #10
boostin13b
boostin13b's Avatar
boostin13b is a well-known jackass
Look at this...........Everyone is all worried about their Narps when everyone knows that Foreskin bushings always go bad way before Narps and can leave you a lot worse off when not replaced or serviced properly.
boostin13b is offline   Reply With Quote
Old 03-02-2007, 08:30 PM   #11
chr0nik_sm0k3
this stuff is weird
Old 03-02-2007, 08:43 PM   #12
super240sx7185
Trader Rating: (83)
super240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond reputesuper240sx7185 has a reputation beyond repute
Feedback Score: 83 reviews
http://cgi.ebay.com/ebaymotors/Harde...spagenameZWDVW
WTF lol that thing looks like it fell out of an automatic transmission lol
super240sx7185 is offline   Reply With Quote
Old 03-02-2007, 09:09 PM   #13
'90RPS13
'90RPS13's Avatar
KEVIN!!!! I have been looking Horrendously (spl?) for a diff warmer. Hook me up bro, I need one. Congrat on the 9,600 post too!
Goldplated? Your fucked. I got platinum. haha.
Old 03-02-2007, 09:14 PM   #14
Phlip
Yes, I look like that
Phlip's Avatar
I got my narps when I went to Auto Zone to get a radiator for my '65 Volkswagen Beetle and some blinker fluid.
Weirdo
And I write too!
Old 03-02-2007, 09:23 PM   #15
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
I got the big narps
New Video
Buy my mounts!
Old 03-02-2007, 09:26 PM   #16
drift freaq
check out the urban dictionary def.
http://www.urbandictionary.com/define.php?term=Narps
New Video
Buy my mounts!
Old 03-02-2007, 09:58 PM   #17
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
I just spent all my tax return ordering my JDM blinker fluid from Performance. I needed it for my amber/clear turn signals. Narps are on the list. I have been looking for the JDM ones for the single cam.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 03-02-2007, 10:07 PM   #18
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
Tomei has a kit with inconel narps, chassis fluid and four hood support gaskets, plus all the correct lines and fluids for 345 dollars, and that includes tire shims and a pre-notched ring land converter set
high performance driveway photography
zenki s14---v8 fc rx7
my crappy flickr page (drift cars whoo)
Pank is offline   Reply With Quote
Old 03-02-2007, 10:16 PM   #19
holybushoffire
holybushoffire's Avatar
holybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant futureholybushoffire has a brilliant future
Send a message via AIM to holybushoffire
Just hope that you don't cut your firing order, because you can only buy 6ft at a time.
holybushoffire is offline   Reply With Quote
