![]() Join Date: Nov 2006
![]() ![]() ![]() Feedback Score: 1 reviews
AFC NEO help
i recently installed my neo and upon installation i went throught the set up process. i have a z32 MAf so i set it to 2 in and 6 out...yadda yadda yadda. 4 cylinder throttle setting in the up position. air map was zeroed acros the board. so no fuel correction. went to start the car and it started and idled at about 2 grand for 5 seconds and then died.
When you initialize it you are compleaty resetting the safc back to what they put in from the factory, so none of your settings are rememberd.
Can you start the car if you unplug the safc and the maf? |
#3 | |
in just blunt ref to your post... if the afc is unplugged there is not signal for maf at all but the car should fire up in "limp mode' of sorts (dont know technical term so dont rape me)... wont rev over 2500 rpms however
Like Me on FaceBook ![]() |
#4 | |
If it dosent then you have other issues. |
#5 |
see i was told that when you initialize the afc it saves the settings. guess i was mis informed. so i can just go in and set everything up and it should work. i have also been told that im going to have some trouble running the Z32 MAF? but it is possible to run it by changing the in and out settings. so that it will run the correct voltage.
