Old 03-04-2007, 08:27 AM   #1
Nskylinerb-25
Nskylinerb-25's Avatar
Nskylinerb-25 is an unknown quantity at this point
Can you Put ABS Rotors in a non ABS 240
Well like the title says can you put ABS rotors on an ABS 240sx this is a 89' 240sx will they fit and will they work the same way as the non ABS rotors............ HELP!!
Nskylinerb-25 is offline   Reply With Quote
Old 03-04-2007, 08:35 AM   #2
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
Let me help you please. I prefer english
"As the title states, I am trying to figure out if it is possible to put ABS brake rotors onto a non ABS 240sx. This is a 1989 240sx. Also, will the fitment and performance be equal to that of the non ABS rotors?"
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 03-04-2007, 08:43 AM   #3
Nskylinerb-25
LOL Thanx for the help Im kind of in a rush here
Old 03-04-2007, 10:12 AM   #4
projectRDM
projectRDM's Avatar
89-94 uses the same size rotor for both ABS and non ABS.
Old 03-04-2007, 11:17 AM   #5
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
Sorry for my little bit of a thread jack here.....
But I'm just wondering cause I actually just called about getting new rotors (for an ABS 240)... and was quoted two different prices. One, higher price, for ABS, and another (lower) for non-ABS. Are you saying I could just buy the cheaper, non-ABS rotors, and they will still work?
mRclARK1 is offline   Reply With Quote
Old 03-04-2007, 11:18 AM   #6
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
^now i know from all my days lurking around here that you know your shit, but from the days work back at the parts store I know they are not the same and autozone, advanced both show different part numbers for ABS and nonABS cars as well as brembo.
If I remember right the non ABS were like .8 inch larger in size. maybe it was just a half inch...either way the ABS model used the same stuff as the altima which had the slightly larger rotor to go along with the larger single piston caliper.
i'm actually on my way out to the store now, i'll check the bremo catalog to see the actual difference is sizes.
O3DigitalBath is offline   Reply With Quote
Old 03-04-2007, 11:25 AM   #7
MaRshMaLLow
MaRshMaLLow's Avatar
MaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond repute
Send a message via AIM to MaRshMaLLow Send a message via Yahoo to MaRshMaLLow
yes the ABS rotors will work on a Non ABS car .. but their more expencive in most cases
Keeping It Real Since 1985
MaRshMaLLow is offline   Reply With Quote
Old 03-04-2007, 11:30 AM   #8
Sanjuro
Sanjuro's Avatar
Sanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really niceSanjuro is just really nice
no, 89-94 ABS / non-ABS rotors are not the same. The parts store gave me the ABS rotors once and I had non-ABS, and the rotors rubbed the calipers like crazy. You have to cut away a bit of the clip in order for the rotor to fit, but its a pain. Get the right rotors and save yourself the hassle.
Sanjuro is offline   Reply With Quote
Old 03-04-2007, 12:18 PM   #9
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
i'm was running 96 S14 SE ABS rotors on my non-abs s13 w/ no problems, until I did the z32 upgrade.
sblack13 is offline   Reply With Quote
Old 03-04-2007, 01:52 PM   #10
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
s13 Chuki ABS rotors are 257x22
s13 chuki NON-ABS rotors are 252x20
the front pads and calipers are also different. rears are the same across the board.
i don't know if this applies to the zenki s13 also but i would assume so.
the reason your s14 rotors worked is because all s14 rotors are the same as the s13 non abs equipment, 252x20.
cdlong is offline   Reply With Quote
Old 03-04-2007, 04:18 PM   #11
ThatGuy
Admin Asshole
ThatGuy's Avatar
Kouki S14 rotors are larger. I know because I just had a set machined to fit inside my non-ABS S13 calipers.
Old 03-04-2007, 05:48 PM   #12
projectRDM
projectRDM's Avatar
I'll be damned. I knew the 97-98s were larger, figured it was just a changeover for the late S14s, so my deduction was the S13s should all be the same. I stand corrected.
Old 03-05-2007, 09:31 AM   #13
cdlong
sorry, i should have said '95 instead of s14 since i got all the info from the '95 and '91-94 FSMs.
Old 03-05-2007, 07:59 AM   #14
Nskylinerb-25
mmmmmmmmmmmmmmmm I don't know I guess I'll get the right rotors the thing is that I can get some Drilled and slotted rotors for $20.00 brand new mmmmmmmm. I'll what happens
Old 03-05-2007, 09:20 AM   #15
sblack13
sblack13's Avatar
hmm so just the 97-98 are different? Like I said earlier, I know the 96 I had working without hassle. But thats pretty interesting.
Old 03-05-2007, 10:06 AM   #16
O3DigitalBath
yea sorry never got back home last night to post up specs from the brembo catalog but the difference is:
9.92 (252mm) without ABS
10.1 (257mm) with ABS
the min thicknesses are also different at
18mm for non ABS
20 with ABS
overall height which is bascially mesasuring the offset or full rotor and tophat hight is the same on both.
non ABS rotors are only used on the 240sx while the ABS ones are used on G20s, ABS 240sx's, Sentra's, and Stanza's.
Old 03-05-2007, 10:13 AM   #17
O3DigitalBath
oh yea, and the difference in price was 3 bucks per rotor so thats worth the extra 5mm then go ahead and get them.
Old 03-05-2007, 10:26 AM   #18
jrocslider
jrocslider's Avatar
jrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfectionjrocslider is close to perfection
no, they are not the same... idk bout those dudes up top giving you wrong info... probably cuase they havent tried puttin ABS rotors on a non ABS 240. i had extra ABS rotors layin around one time and thought the same thing... they sould fit... nope
jrocslider is offline   Reply With Quote
Old 03-05-2007, 12:31 PM   #19
O3DigitalBath
we have already established they are not the same...but is the 5mm difference in diameter too much of a difference so that they rub the caliper?
Old 03-05-2007, 12:48 PM   #20
Nskylinerb-25
Well Im going to buy them it's only $20.00 it's a hell of a deal and I'll let you guys know what happens and if I can make them fit I also forgot I don't have stock 240 rotors I have the Infinity M30 front rotors wich are alittle bigger so I'll see what happens.........
