Old 03-04-2007, 08:38 AM   #1
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
anyone having problems with stance?
i know a few guys here that are having some problems with stance, specfically spontaneous lowering (lowering by itself) and some other misc problems.
anyone having this particular problem with their stance?
would like to hear your opinions either it be bad/good
thanks
ps: how does everyone feel about the adjusters for the damper and if they feel that they are too close to the ground?
some people are getting theirs damaged by rocks etc since it sits lower to the ground becuase of the characterisitcs of inverted monotubes. anyone design a way to protect the adjuster in any way?
overb0ost is offline   Reply With Quote
Old 03-04-2007, 09:16 AM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Take the adjuster off so you only use it when you need it?
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 03-04-2007, 10:11 AM   #3
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
My biggest suggestion if you do have problems call STANCE.
In terms of those problems I have yet to hear any S-Chassis owners with issues like that. It can't spontaneously lower unless your collars are loose. They have to move in order for anything else to move. The problem you might be thinking of is the springs settling, after a little while of driving springs settle so it will be lower a few weeks after you first put them on.
For the adjuster ya it sits low, but rocks can jump around wherever they want to jump around, if the actual clicker breaks thats in stock at STANCE, otherwise you can just leave the gold knob off and just use it when you need to adjust.
In my personal experience on the knob, the gold knob is on mine and my car is low, so far no rocks have it it or my shock body.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 03-04-2007, 10:32 AM   #4
!Zar!
!Zar!'s Avatar
I don't run stance, but when I ran KTS the perches loosened on me a few times. Even after busting a knuckle or two when tightening it down, it would still loosen. So what I did was lightly scratch a line down the threads. That fixed the problem of spontaneous loosening.
The kts are also invert mounted. The knobs worked find and had no adjustability problems when I had them.
Old 03-04-2007, 12:58 PM   #5
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
All coilover collars spontaneously come loose. You just have to check them frequently and listen for clunks when you are driving.
Flybert is offline   Reply With Quote
Old 03-04-2007, 01:03 PM   #6
Dousan_PG
Dousan_PG's Avatar
u have the reall snug those puppies down
mine slipped down
so i redid it later
and used a screw driver and hammer and gotthem perches REAL tight and snug. its the only way to do it.
the top bolt all coivres do that too
basically what u are running into is NOTHINg new.
every coilover eventuallyruns into this deal.ive had Tein HE, JIC FLTa2, Tanabe DDs and these (s14 and s13) and they allshare same problems.
my knobs are fine, thanks for asking
Aaron
Pink GodziRa
Old 03-04-2007, 01:07 PM   #7
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
My Zeals lower on their own.
Kind of a pain.
I just know it is time to raise the car again when I start hearing certain scrapes on certain parts of the ground.
http://bhworld.wordpress.com/
Old 03-04-2007, 01:15 PM   #8
wootwoot
You guys ever hear a loctite? I heard that stuff might help out a bit too.
Old 03-04-2007, 01:17 PM   #9
Nachtmensch
Nachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond reputeNachtmensch has a reputation beyond repute
never had any problems with my STANCE coilovers
Nachtmensch is offline   Reply With Quote
Old 03-04-2007, 01:34 PM   #10
Brian
Brian's Avatar
Trader Rating: (54)
Have you guys ever heard of Loctite? I heard that that stuff might help out a bit.
To answer your question, yes I have heard of it. I own some actually. I bet it would help. Am I going to use it? No.
Old 03-04-2007, 01:58 PM   #11
NemeGuero
No more nissan.
NemeGuero's Avatar
Yah, I wouldn't loctite collars either.
Old 03-04-2007, 02:37 PM   #12
wootwoot
But why not?
Old 03-04-2007, 02:51 PM   #13
kdashy
kdashy's Avatar
kdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfection
Send a message via AIM to kdashy
Do they have a loctite application that doesnt break from vibration or require a torch to take off?
kdashy is offline   Reply With Quote
Old 03-04-2007, 03:29 PM   #14
chmercer
chmercer's Avatar
But why not?
if you have problems with your lock collars coming loose you probably have pencil arms or are tightening the collars with your hands or something. there is no reason you should ever need to use loctite on a shock body. sometimes i can barely get my coilovers apart with a sledge and a punch and half a bottle of wd40. i can only imagine if there was loctite in the threads.
chmercer is offline   Reply With Quote
Old 03-04-2007, 03:43 PM   #15
McRussellPants
lol putting loc-tite on collars, shit is gonna seize in like 5 days.
I've never had a lower collar loosen, usually the problem lies in getting them loose.
McRussellPants is offline   Reply With Quote
Old 03-04-2007, 04:14 PM   #16
A Spec Products
A Spec Products's Avatar
Loctite? Baby stuff.
Just weld the collars together.
Yep, that'll do it.
But on a serious note, if you ever have a problem with any product in any sector, just contact the manufacturer first.
A SPEC PRODUCTS CORP
Old 03-04-2007, 04:40 PM   #17
KiDyNomiTe
KiDyNomiTe's Avatar
My silk roads just rusted together never moved again...
PROCEED
Grip Gambler
Old 03-04-2007, 04:47 PM   #18
jjwilks240
jjwilks240 is making a name for him/her selfjjwilks240 is making a name for him/her selfjjwilks240 is making a name for him/her self
haha, i cant belive nobody mentioned zipties. mine always came loose after a few weeks so i just cranked a ziptie on there to help with the suttle spinning of the collar. works like a charm... we did this on some of the stock car chassis i worked on.
Image Exceeds Forum Limits.
jjwilks240 is offline   Reply With Quote
Old 03-04-2007, 04:57 PM   #19
jspecusa
jspecusa's Avatar
jspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfectionjspecusa is close to perfection
Send a message via AIM to jspecusa
after doing many track events we realized that some of the suspesion nuts/bolts will come lose.
it's good to check it every oil change.
don't wait til noise come out, usually it's from all the stress and impact of the suspension.
that's including tension rods, upper arms, etc.
cheers,
sam
Nissan Japan: "road to happiness has many curves"
Jdmlivin: "Jdm is dead, the yen is crazy"
jspecusa is offline   Reply With Quote
Old 03-04-2007, 05:22 PM   #20
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
teflon tape?
SochBAT is offline   Reply With Quote
Old 03-04-2007, 07:14 PM   #21
!Zar!
!Zar!'s Avatar
JBweld. or you could just remove all the collars. Problem solved.
Old 03-04-2007, 08:22 PM   #22
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
thread synopsis: my pussy hurts and my arms are tiny
KEEP CHARLIE MERCER BANNED HES A GOOD FOR NOTHING RACIST
lilredstiffy is offline   Reply With Quote
Old 03-04-2007, 09:59 PM   #23
kdashy
kdashy's Avatar
The top bolts get loose from time to time too. making clunking sounds when it loads/unloads.
Old 03-04-2007, 11:17 PM   #24
NemeGuero
No more nissan.
NemeGuero's Avatar
I locked my shafts with a rag, vice grips and used an impact on the top nut and my pillowballs still knock. Explain that! lol
Old 03-05-2007, 08:16 AM   #25
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
I use a rubber hammer on the spanner wrenches that come with coilovers. Tein HE collars would come loose on the front driver's side no matter how tight. My Zeals are reverse threaded on the front driver's side only... maybe to prevent coming loose? I don't know but they haven't come loose on their own
FinalDrive is offline   Reply With Quote
Old 03-05-2007, 11:06 AM   #26
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
The lower collar on my front driver side HE would come loose once a week for a while too. Then I used a hammer and a punch to tighten it up that last .5mm I couldn't get with the spanner wrench. That was like a year and half ago. No problems since.
sncs14 is offline   Reply With Quote
Old 03-05-2007, 11:28 AM   #27
LB.Motoring
LB.Motoring's Avatar
even with my pencil arms collars never came loose, just tapp them together, and check regularly.
Robby Leuer
Old 03-05-2007, 01:44 PM   #28
The Riot Hero
Banned from the Marketplace
The Riot Hero is on a distinguished road
Send a message via AIM to The Riot Hero Send a message via Yahoo to The Riot Hero
ive been using stance for awhile now, great coilovers for the money, i snugged my collars down pretty good and never had any problems!
The Riot Hero is offline   Reply With Quote
Old 03-05-2007, 01:54 PM   #29
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
yea, I got my car on a lift today and fount mine were loose, but yea, it's a coilover, snug them bitches up or else they are going to move. Not Stances fault.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 03-05-2007, 03:28 PM   #30
Gumballf355
Gumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to behold
Send a message via AIM to Gumballf355
Use a spot of loctite on the thread... that'll do the trick.
Gumballf355 is offline   Reply With Quote
