![]() Join Date: May 2001
Hey all,
I just got the APEXi N1 Dual and was wonderin what size hi-flow cat would I use on it? A 2.5inch or 3inch cat? Sorry if this has been posted before, I'm busy installing my Intrax springs and KYB shocks... Thanks In Advance |
To be honest with you I have the Random Tech cat and they don't offer(or at least I don't think they do)different diameters in there cats. Other manufacturers may be different, but 2.5 inch is the only size that I'm aware of.
![]() Join Date: Jun 2001
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from S14KAT on 10:39 pm on Feb. 1, 2002
To be honest with you I have the Random Tech cat and they don't offer(or at least I don't think they do)different diameters in there cats. Other manufacturers may be different, but 2.5 inch is the only size that I'm aware of.</td></tr></table><span id='postcolor'> did it make a big difference in performance? |
#5 |
You CAN get 3" diameter inlet/outlet cats from Random instead of the 2-1/2" diameter they list for the 240SX. For the 89-97 240SX, Random lists the 2-1/2" diameter cat as part number as 822530...but according to Random, part number 823030 is a 3" diameter cat which was made for the Maxima, but will work for the 240SX as well.
If the N1 dual has a 3" inlet, I would recommend the 3" Random Tech Cat since the Random Cats have slip type flanges. What I mean is that the mounting flange of the cat is free to slide and rotate on the inlet and outlet pipes of the cat. So if you get the 2-1/2" Random Cat, the outlet pipe may be swallowed by the N1 exhaust making it difficult to seal properly without a steel reinforced exhaust gasket. |
#6 |
Well to my further research, I think the APEXi N1 Dual is 2.5inch in diameter, and I heard the APEXi N1 Single is 3inch with a 2.5inch converter that you can take off when you go turbo ?? (Not sure on that, if someone can explain for me) ....I'm staying N/A for a while so I'm gonna stick with 2.5inch hi-flow cat...
