Old 03-06-2007, 08:13 PM   #1
gotta240
MOTHER F'ING brake booster removal....
I've removed a few brake boosters...everyone i've delt with connects to the brake pedal with a simple pin(slides through) and a clip to hold it in place.
I'm trying to remove an abs 95 240 brake booster. I have the little clip out but i can't get the dowel out for the life of me...wtf am i missing?
Old 03-06-2007, 08:17 PM   #2
Blackparade
Blackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfection
The dowell thing is flared on the side that the clip was on. I grab it with a pair of needle nose to compress the flares, and start putting it through.
Blackparade is offline   Reply With Quote
Old 03-06-2007, 09:01 PM   #3
iiEddieGii
iiEddieGii is a well-known jackass
Send a message via AIM to iiEddieGii
blackparade is right, the clevis pin has a plastic piece on the end that needs to be pinched to get it to go through the hole.
iiEddieGii is offline   Reply With Quote
Old 03-06-2007, 09:09 PM   #4
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
ya its pretty much a bitch. but once you get it out putting it back in is no problem lol.
sbanzer123 is offline   Reply With Quote
Old 03-06-2007, 09:33 PM   #5
gotta240
Great. Thanks a lot guys, much appriciated.
Old 03-07-2007, 04:04 AM   #6
g6civcx
g6civcx's Avatar
I recommend getting a new clevis pin and clip from the dealer. Then you can cut the old one off if you have to.
Be careful because it's easy to lose the clip. It likes to fly off when you remove it from the clevis pin.
