Old 03-10-2007, 03:59 AM   #1
kY.gordon
Banned from the Marketplace
kY.gordon's Avatar
kY.gordon can only hope to improve
How to remove the gas tank?
long story short, drilled a small hole into the gas tank when relocating battery to the trunk. I know there is a hole because my tank does not depresurize when i remove gas tank cap and my cabin smells like gas at times. Maybe I can just shove a bolt into the hole or use some of that quick tire patch rubber and shove it down the hole. I also have a s13 fastback parts car but dont know if the gas tank in the fastback and my coupe (the one with the hole) are interchangable. Lost my chiltons and cant the FSM's from that one site online has been down for a while. Help me out!
kY.gordon is offline   Reply With Quote
Old 03-10-2007, 04:09 AM   #2
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
remove the Fuel Pump.
Remove bracket holding gas tank mouth.
Remove 2 metal belts holding tank to chassis.
FSM is your friend.
SochBAT is offline   Reply With Quote
Old 03-10-2007, 08:25 AM   #3
projectRDM
projectRDM's Avatar
FSM is your friend.
Bingo. Drops out like butter, couldn't be easier.
Old 03-10-2007, 04:26 AM   #4
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
why would you drill a hole int your gas tank.
sbanzer123 is offline   Reply With Quote
Old 03-10-2007, 04:37 AM   #5
SochBAT
Are you serious?
Old 03-10-2007, 05:31 AM   #6
kY.gordon
kY.gordon's Avatar
havent you watched simpsons? speed holes.
Old 03-10-2007, 08:36 AM   #7
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I guess thats the reason why you been so busy you couldn't refund me my money.
Jung918 is offline   Reply With Quote
Old 03-10-2007, 01:07 PM   #8
SochBAT
Easy peasy.
Wow, i totally forgot about that Jung.
haha.
Old 03-10-2007, 01:29 PM   #9
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
yeah to patch it you can just take a screw that fits tight in the hole and pack some silicone around it. seen it done before, works quite well.
lazierhobo is offline   Reply With Quote
Old 03-10-2007, 03:40 PM   #10
SochBAT
tahts why you're lazier hobo.
