Old 03-11-2007, 09:34 AM   #1
Dripht240
Dripht240 is an unknown quantity at this point
Will a dohc nissan altima wiring harness work in an S13?
i did a search and couldnt find any results for my question but has anyone tried or knows if using the wiring harness off the dohc altima (93-97) would work when doing a dohc swap into an 89-90 s13?
Dripht240 is offline   Reply With Quote
Old 03-11-2007, 09:44 AM   #2
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
i very dout it haha
too different in cars... fwd rwd. intake mani total diffrent...
ur better off tryin to make ur sohc work on ur sohc
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 03-11-2007, 09:55 AM   #3
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
No it will not work cause the sensor for the transmission might be different. Also year of the altima might not be running a ignition coil like most ka24de. So i would say find a s13.If you come by a s14 wiring harness it could work too if you have a s14 maf and i think distributor.
CA18_S13 is offline   Reply With Quote
Old 03-11-2007, 10:42 AM   #4
g6civcx
g6civcx's Avatar
I have not tried it, but a wiring harness is just a bunch of plugs and wiring tied together. You can make any wire harness work in any car if you have the right plugs and reroute the wires correctly.
If you want plug-and-play, then no.
Old 03-11-2007, 11:00 AM   #5
Dripht240
thanks for the info i kind of figured with the difference in fwd and rwd but i figured i would make sure anyway. Finding uncut wiring harnesses for dohc is tough enough but you can find altimas all day... *sigh* wishful thinking
Old 03-16-2007, 02:09 PM   #6
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
i have your answers, i just bought a 93 hb with a 94 altama ka24de and it ran ok when i first bought it then it broke, i change the coil, plugs and now its not holing any compression, it drove good somwhat, trust me i thought it was a good idea but now it sucks, so im looking for A KA24DE 91*
240trooper is offline   Reply With Quote
