Old 03-17-2007, 02:15 PM   #1
D1_King
D1_King is an unknown quantity at this point
OverHeating Problem
ok i have a KA24DE and the compresion is up.it has
ka24e pistons,
Port and Polished
oversized valves and springs
it overheats for some reason and i cant find the problem.
i checked cooleint and everything. it seemed right.
D1_King is offline   Reply With Quote
Old 03-17-2007, 02:21 PM   #2
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
check your thermostat. replace, flush the radiator real good, put new fluild in. should solve.
what kind of fans do you run? stock radiator?
hydropgrahics!
ls1......
Old 03-17-2007, 02:51 PM   #3
D1_King
Koyo Radiator and Flexlight and i already did do the fluid stuff
Old 03-17-2007, 03:02 PM   #4
johngriff
johngriff's Avatar
Given, the block/headgasket etc is in good shape.
Air in System, bleed accordingly.
[email protected]
Old 03-17-2007, 03:19 PM   #5
I_DID_SILVIA
I_DID_SILVIA's Avatar
I_DID_SILVIA has a spectacular aura aboutI_DID_SILVIA has a spectacular aura aboutI_DID_SILVIA has a spectacular aura aboutI_DID_SILVIA has a spectacular aura aboutI_DID_SILVIA has a spectacular aura aboutI_DID_SILVIA has a spectacular aura about
does it still heat up when you put the heater on? or have you even tryed that yet?
I_DID_SILVIA is offline   Reply With Quote
Old 03-17-2007, 03:37 PM   #6
D1_King
i havent put on the heater yet
Old 03-17-2007, 04:34 PM   #7
240sxworkinprogress
240sxworkinprogress's Avatar
240sxworkinprogress is a well-known jackass
Have you ever replace the coolent temp sensor? The sensor between the S13and S14 are different. If you put a S13 sensor in a S14 it always read hot.
If you haven't replace the sensor then I would just do what 420sx says. Also check to make sure your headgasket is in good shape and the head.
240sxworkinprogress is offline   Reply With Quote
Old 03-17-2007, 05:28 PM   #8
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
Do all of the above and also check that all of your hoses are tightened. Check all of them for any trickling of AF, as that is an indicator of a pressuruzation leak, which also allows for air to enter the system. If an air bleed fixes the problem temporarily, then this may be your problem.
zero.counter is offline   Reply With Quote
