Old 03-23-2007, 07:47 PM   #1
gotta240
First i find out Santa isn't real, NOW THIS?!
Seriously though,
Who has found that tires sizes arent always an ACTUAL indicator of their size? I have a set of potenza's in a 245 wide, on a 8" 350z rim. I also have a set of some cheapo tires in a 225 wide on a 300zx rim. THEY ARE IDENTICAL IN WIDTH. I measured the "useable" width...IDENTICAl. I measure total tread width...IDENTICAL.
Maybe i'm retarded and everyone knew this....but seriously, how can they legally sell tires(a safety item) in a size that isn't really that size?!
Old 03-23-2007, 07:56 PM   #2
kandyflip445
kandyflip445's Avatar
Maybe it's like that thing in F1 awhile back. The tread would get wider as the tire wears down.
My 240 vBgarage
Old 03-23-2007, 08:04 PM   #3
seekanddestroy
seekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choicesseekanddestroy has made poor choices
It depends on the construction of the tire, the width measurement (section width) is from the middle of the sidewall across. Sidewall height (which is a percentage of width) would cause the tread width to differ.
Example, a 245/40/17 may have a 9" wide tread, while a 245/70/15 would have something like a 7" wide tread.
seekanddestroy is offline   Reply With Quote
Old 03-23-2007, 09:05 PM   #4
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
I guess I'm not the only one, just found out about this too.
WilloW is offline   Reply With Quote
Old 03-23-2007, 09:26 PM   #5
gotta240
Thats retarded. I always thought the width was a "hard" measurement of the TREAD width.
Old 03-23-2007, 10:07 PM   #6
!Zar!
!Zar!'s Avatar
Tire sized vary depending on the manufacture.
Old 03-23-2007, 11:34 PM   #7
OptionZero
OptionZero's Avatar
Duh.
Example: RT-615's always give you a little extra width compared to its rivals.
OptionZero is offline   Reply With Quote
Old 03-23-2007, 11:58 PM   #8
projectRDM
projectRDM's Avatar
Old, old, old news. Tire manufacturers produce their tires based on a dozen different variables, there's no set standard. Some run wider than others, some run taller.
Old 03-24-2007, 10:35 AM   #9
gotta240
WHAT variables? A measurement is a measurement! (no doubt you are right, just doesn't make sence)
next you're going to tell me the easter bunny is fake... i can't take this!!!!!!
Anything else off that i should know about? You know, like certain oil companies making their 10w30 thicker or thinner than others! lol. Ok. DONE beating this topic.
Old 03-24-2007, 12:56 PM   #10
OptionZero
OptionZero's Avatar
A measurement is a measurement but where you measure from is not necessarily where someone else measures from.
And of course, there's always lying for the sake of, i dunno, making more money?
In other breaking news, water is wet.
Old 03-24-2007, 06:00 PM   #11
articdragon192
articdragon192's Avatar
Just like different shoe brands use different measurements. I'm an 11-12.5 depending on shoe and brand. Tire size varies from company to company.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 03-24-2007, 06:26 PM   #12
twofourzerosx
twofourzerosx can only hope to improve
santa isnt real?
twofourzerosx is offline   Reply With Quote
Old 03-24-2007, 07:06 PM   #13
chibo
chibo's Avatar
chibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfectionchibo is close to perfection
Send a message via AIM to chibo
Of course, go look at offroad tires, some '35"' tires measure 33.8" while others measure a little over 35"
chibo is offline   Reply With Quote
Old 03-24-2007, 07:31 PM   #14
ronmcdon
ronmcdon's Avatar
this is true for a lot of things, not just automotive parts. simply because there is no universal meticulous criterion of measuring the item in question among all merchants in the given field. even if there are rules, the enforcement of the given rules may be inconsistent (if not non-existent as well). thats just to be expected imo.
if its any consolation, i don't think merchants are going to allow inconsistent products to get to the point where it jeopardizes safety though. there still are civic lawsuits in this country, for better or worse.
regardless i would wager to guess that the inconsistencies in tire sizes are prob negligible for the most part. i think tirerack.com shows info on the actual specs of all tires including actual width.
btw- you are sadly mistaken about santa. just b/c he doesn't visit you, doesn't necessarily mean he doesn't exist. :P
Old 03-24-2007, 07:33 PM   #15
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Originally Posted by twofourzerosx
santa isnt real?
He was just joking about that part.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 03-24-2007, 07:41 PM   #16
A Spec Products
A Spec Products's Avatar
It's your fault for running 245s on a 8.
LOL
Kidding
But tires have a range of width that the size can be run on, so being off by 10-20mm in width I suppose doesn't jeopardize safety.
If it beads, holds air, and drives fine, I don't see a safety issue.
A SPEC PRODUCTS CORP
Old 03-25-2007, 04:57 AM   #17
xtreme_s14
xtreme_s14's Avatar
xtreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond reputextreme_s14 has a reputation beyond repute
Send a message via AIM to xtreme_s14
yay! with that said.. i would have no doubts we'll be seeing "will [brand tire & size] fit on my [size] wheel" threads! ..not that we don't already!
so.. i have federal 225/40/18 and 235/40/18! will those fit on my 18x9.5 wheels with a nice stretch?
JUST KIDDING!@#$%
xtreme_s14 is offline   Reply With Quote
Old 03-25-2007, 06:47 AM   #18
g6civcx
g6civcx's Avatar
To the original poster, please do your homework and refrain from posting until you've done so.
http://www.tirerack.com/tires/tirete...p#measrimwidth
Old 03-25-2007, 11:42 AM   #19
A Spec Products
Originally Posted by anonymous
Don't you pretty much sell wheels for a living? Shouldn't you know something about tires?
"But tires have a range of width that the size can be run on, so being off by 10-20mm in width I suppose doesn't jeopardize safety."
Are you fucking kidding me?
Tread width depends on many things, the original poster stated that he had a 225 and a 245 and that according to his measurements, the tread width was the same. First off, I wouldn't trust someone who cannot even coherently type messages with a measuring tape. Second, tread width depends on the profile of the tire as well wheel size. Yes, some tires do have differently shaped shoulders, and some do differ in tread width with the same size, however, all the information you would ever need on a tire is on the manufacturers website. His post is absolute garbage, this place is a complete joke.
Good day.
Someone who posted in this thread took it upon himself to spread the joy of his weekend and send me this PM. Way to start my Sunday off on the right foot, eh?
To clarify, I was saying that you can throw a 215/40/17 on a 7" rim, an 8" rim, or a 9" rim. All of those work, although I'm sure the manufacturer would never recommend it for a 9.
So if he uses a 225 or 245 and either fits, who cares. Next time when you buy tires just choose the one that fits your budget and preferences.
People get way too bent out of a shape sometimes.
Old 03-25-2007, 11:58 AM   #20
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
I don't even know why that guy PM'd you. Your post made sense to me.
Flybert is offline   Reply With Quote
Old 03-25-2007, 12:10 PM   #21
gotta240
I don't know why that guy pm'd you either, and to the guy who DID PM YOU
FUCK YOU. First- What was wrong with the way i typed that thread(not by english class standards, by e-standards?)
Second- I measure all day every day for a living. Being a 1/16th off can be the difference in quality and crap. My measurements are correct so STFU.
Old 03-25-2007, 12:23 PM   #22
A Spec Products
It's like that one insurance commercial, where the one dude lets the lady walk at the crosswalk in front of him.
Then that lady does something nice for someone else, who in turn does something nice for someone else, and then eventually it comes full circle to the original dude, having someone do something nice for him.
That's how I wish the world would work, instead of spreading negative energy, which thereby spreads more negative energy.
