Old 04-10-2007, 05:41 PM   #1
cjturbos14
cjturbos14's Avatar
cjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura about
What size tires w/ 18x9 +8 F 18x10.5 +14 R?
Just bought some work vsxx 18x9 +8 fronts 18x10.5 + 14 rears, I'm going to need to roll my fenders and I want a nice stretched look. What do you guys think?They're going on my s14.
cjturbos14 is offline   Reply With Quote
Old 04-10-2007, 06:05 PM   #2
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
225 and 235 for the stretched look...
But I would run a 245 and 255 and have a not-so-stretched look...
Nikeboy355 is offline   Reply With Quote
Old 04-10-2007, 06:14 PM   #3
drift-it
drift-it's Avatar
drift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-known
Send a message via AIM to drift-it
225 40 18 front and 245 40 18 rear. 235 40 18 on a 10.5 is really stretched and most places (any place you would probably have your vsxx's at) wouldnt do that unless you had a friend there.
drift-it is offline   Reply With Quote
Old 04-10-2007, 06:32 PM   #4
topsecretgold
topsecretgold is a jewel in the roughtopsecretgold is a jewel in the roughtopsecretgold is a jewel in the roughtopsecretgold is a jewel in the roughtopsecretgold is a jewel in the roughtopsecretgold is a jewel in the roughtopsecretgold is a jewel in the rough
225 in the front will be perfect...and only a roll will be necessary. In the rear anything from 245-265 will work, you should choose based on how much power you are going to be putting to the ground/ or if you are going to be drifting it. i have 18x9.5 +12 w 235/40/18 and it JUST BARELY tucks in to clear the rear fenders so with 18x10.5 +14 you will have to pull but you probably already know that. just figured id put in my two cents, i hope it helps.
topsecretgold is offline   Reply With Quote
Old 04-10-2007, 06:34 PM   #5
skate07
skate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-knownskate07 is making his/her stupidity well-known
225 on the front will not look stretched if you are using expensive tires... 215/40 will yield the stretched look, or buy cheap 225's....
for the rear, 235/40 is jazzy
skate07 is offline   Reply With Quote
Old 04-10-2007, 06:43 PM   #6
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
i run 245/35 255/40 front and rear look in my cardomain to see pics
wheels are 18x9 and 18x10
bigOdom1 is offline   Reply With Quote
Old 04-10-2007, 07:55 PM   #7
staygold24
staygold24's Avatar
staygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enoughstaygold24 will become famous soon enough
somebody bought from rbmotoring.
staygold24 is offline   Reply With Quote
Old 04-10-2007, 08:06 PM   #8
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
so what? It's not like they were cheap
kevtrinh is offline   Reply With Quote
Old 04-10-2007, 08:08 PM   #9
IchigoMae
IchigoMae is an unknown quantity at this point
Send a message via AIM to IchigoMae
id go with 215 40 18 in the front, if you say you want that "nice stretch look"
IchigoMae is offline   Reply With Quote
Old 04-10-2007, 08:39 PM   #10
cjturbos14
cjturbos14's Avatar
maybe you guys can post pics of how each size looks?
Old 04-10-2007, 09:19 PM   #11
cjturbos14
cjturbos14's Avatar
yes sir rbmotoring I guess ill go with 215 40 F 235 40 R will I really need to pull the rear?
Old 04-10-2007, 10:38 PM   #12
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
with 10.5 +14, you will need to pull the rear. or 3 to 4 degree of neg camber and you will only need a roll.
driftingisgay.com
nrg is offline   Reply With Quote
Old 04-10-2007, 10:51 PM   #13
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
215 in the front! not the rear. for the raer i would recommend a 245. i wish you the best of luck.
TEAM SUS*PECT
Old 04-10-2007, 10:58 PM   #14
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
255 front
295 rear
Read sig
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 04-10-2007, 11:12 PM   #15
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
i would go with a 215/40/18 up front and a 235/40/18 rear
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-10-2007, 11:29 PM   #16
datboibrad
datboibrad can only hope to improve
stretch is for broke folks =p
datboibrad is offline   Reply With Quote
Old 04-10-2007, 11:49 PM   #17
cjturbos14
cjturbos14's Avatar
Yeah I'm probably going to have to do a negative camber in the rear w/ the roll. Hopefully the RUCA's and toe rods get here before the wheels.
Old 04-11-2007, 01:13 PM   #18
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
255/35 18 and 275/30 18
95zilvia is offline   Reply With Quote
Old 04-11-2007, 01:53 PM   #19
Gaelen
Gaelen's Avatar
Gaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfectionGaelen is close to perfection
it would probably help if you told us what you were running suspension and motor wise
and what you planned to do with the car
Gaelen is offline   Reply With Quote
Old 04-11-2007, 03:22 PM   #20
cjturbos14
cjturbos14's Avatar
I'm going with
k sport coilovers
k sport tension rods
k sport RUCA
power trix traction rods
power trix toe rods
I'm planning to do some drifting but not on these wheels, and I have a s13 Blacktop sr.
Old 04-11-2007, 03:24 PM   #21
cjturbos14
cjturbos14's Avatar
I found some 215 45 18 and 245 45 18 pretty cheap what do you guys think?
Old 04-11-2007, 03:50 PM   #22
95zilvia
You're retarded.
Old 04-11-2007, 03:54 PM   #23
bigOdom1
bigOdom1's Avatar
time for the danza slap
Old 04-11-2007, 03:57 PM   #24
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Personally, I'd go with 215/35's on the 18x9's and 235/40's on the the 18x10.5's.
Old 04-11-2007, 04:18 PM   #25
Gaelen
Gaelen's Avatar
I'm going with
k sport coilovers
k sport RUCA
power trix toe rods
stock sr?
if it is and since you arent going drifting but want a stretched look i'd go with 225/40 F 245/40 R
you will still keep some traction but will get a decent look out of it
if you want really stretched do a 235/45 rear but i dont suggest it
but again....just my opinion
Old 04-11-2007, 09:22 PM   #26
cjturbos14
cjturbos14's Avatar
It's cool I'll go 215 40 F 235 40 rear I'll post pics when I'm done.
Old 04-12-2007, 12:04 AM   #27
cjturbos14
cjturbos14's Avatar
this is the look I'm going for
Old 04-12-2007, 10:04 AM   #28
sultan
sultan's Avatar
sultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enough
you're not gonna get that look with 18's on the rear
sultan is offline   Reply With Quote
Old 04-12-2007, 02:01 PM   #29
cjturbos14
cjturbos14's Avatar
ill get somewhat that look
Old 04-14-2007, 02:06 PM   #30
cjturbos14
cjturbos14's Avatar
Here it is. Still got to install ruca's and toe rods.
