Old 04-12-2007, 04:14 AM   #1
GROUND_ZeRO
GROUND_ZeRO's Avatar
GROUND_ZeRO is an unknown quantity at this point
Send a message via AIM to GROUND_ZeRO
Lsd
I got an s13 coupe, and I know it doesn't have an LSD. I heard the 300zx LSD fits in there. Is that true? If so, could someone give me the step by step of how to install the 300zx LSD into a s13 rear end. Thanks!
YOU WANNA SEE ME SWING IT? INTO YOUR MOUTH!
GROUND_ZeRO is offline   Reply With Quote
Old 04-12-2007, 04:31 AM   #2
Chez
Chez is making his/her stupidity well-knownChez is making his/her stupidity well-knownChez is making his/her stupidity well-known
your not gonna last a day if you dont learn to search.
Originally Posted by ixfxi
Stick with high quality italian made rotors, and you dont have a problem. Go with cheap, made in china bullshit.. and like most of anything made in china, you end up with fried rice.
Chez is offline   Reply With Quote
Old 04-12-2007, 07:16 AM   #3
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
10 seconds on google
http://importnut.net/lsdswap.htm
ladiesman8527 is offline   Reply With Quote
Old 04-12-2007, 10:10 AM   #4
Canaduh
Canaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of lightCanaduh is a glorious beacon of light
I bet there is at LEAST 10 posts on the first page you search "VLSD install"
Canaduh is offline   Reply With Quote
Old 04-12-2007, 10:47 AM   #5
!Zar!
!Zar!'s Avatar
VLSD is for fags. I'm sure the OP doesn't want to be a fag.
Buy a 2way if you have extra scrill.
Since you're in the bay, I highly suggest checking out Luke's Weld Locd v4 diff. Don't deal with all that other bs.
Old 04-12-2007, 01:28 PM   #6
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
to the OP whats the purpose of your car should be the #1 question to determine what kinda diff he wants to use?
pbcstylez is offline   Reply With Quote
Old 04-12-2007, 02:06 PM   #7
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
From your post I assume you're into drifting, and that you're broke/on a tight budget. With those parameters, instead of messing around with a 300z Viscous LSD, you should look into getting your stock open differential welded like !Zar! said. Luke does an excellent job and the price on his "Weld Loc'd V4" should be in your range:
http://www.zilvia.net/f/showthread.p...highlight=weld
Install is relatively simple if you're a habitual/weekend wrencher... Take a look at the link in my signature for a Kaaz LSD Install. A welded diff install is almost identical.
On the other hand, if you have a $500 to $1000-ish budget for a brand new diff, you should look into getting a Kaaz, Nismo, Cusco brand 1.5 or 2 way LSD. If you're not sure what the difference is between "V LSD", "1.5 way" and a "2 way" then you still have some important homework to do before you make ANY decision... BTW just do a search for "weld" and you'll find tons of "debate" threads on here regarding HLSD, VLSD, 1-way, 1.5 way, 2 way and welded diffs. Start here: http://auto.howstuffworks.com/differential.htm.
MELLO*SOS is offline   Reply With Quote
Old 04-12-2007, 02:29 PM   #8
qwikspool
qwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfectionqwikspool is close to perfection
Send a message via AIM to qwikspool
hey i searched something for you and this is what it came out. try clicking on the link. hopefully it works out for you. http://www.240sx.org/links/installs/lsd/lsd.htm
getting a vlsd is not worth it. if you are on a budget get your open diff welded.
qwikspool is offline   Reply With Quote
Old 04-12-2007, 02:57 PM   #9
exitspeed
aWingThing.com
exitspeed's Avatar
This is old, but will answer anything you want to know about R200 LSD install.
It's cheap, easy, and it's an LSD. There are better, and more expensive options out there. It's not bad (better then open), if you're on a budget. Like others have said if you wanna drift, have you're open diff welded. If you wanna AutoX and you're on a budget it'll work.
GO here
Old 04-12-2007, 07:01 PM   #10
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
"welded diff is the poor drifter's answer to LSD" get it, don't even waste time with VLSD.
Old 04-12-2007, 07:24 PM   #11
s14xman
s14xman's Avatar
s14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of light
Send a message via AIM to s14xman
+1 for welded, or else save for lsd, don't waste money on vlsd
FRontline (marinating since 02)
s14xman is offline   Reply With Quote
Old 04-16-2007, 02:32 AM   #12
GROUND_ZeRO
I know what VLSD is, 1 way, 1.5 way, 2 way, welded, etc. I am into drifting, but I might as well start off cheap before I go with the high prices, that way I save money to buy Kaaz Lsd, suspension, piping or what not. I know VLSD's are not that great, but it's something far from nothing. I agree with PBCSTYLEZ.. I decided what I wanted to use and I am asking a simple question: How do you install the 300zx LSD. That's it... And I posted this cause I know that there is different opinion than the one on the tech. forum. Other people's opinion's matter, but I just have to do the decision. Thanks everyone
Old 04-16-2007, 02:44 AM   #13
panama DRIFT
panama DRIFT's Avatar
panama DRIFT is an unknown quantity at this point
Send a message via AIM to panama DRIFT
s15 hlsd
just my 2 cents though
they are pretty cheap
and reliable
panama DRIFT is offline   Reply With Quote
