Old 04-13-2007, 09:35 PM   #1
hellllo
hellllo can only hope to improve
Few Suspension questions
I can't find answers to my specific questions but here it goes. Note: I'm still learning about cars, so please don't flame. Quick history, my bro passed away and I'm left with his car. I don't know much but I'm learning.
I just noticed my driver side wheel sticks out more than the passenger. How can i adjust it so they are even? I've torqued down my lug nuts, and checked control arms. They look good.
I'm running alot of caster, I'm wondering how can it, to be running 0 degree caster.
I know how to adjust camber on the front suspension (camber plates), but how do i adjust camber in the rear, they don't have camber plates.
My bro's car has following suspension mods
Tein coilovers, tension rods, and rucas
Thanks for your patience
hellllo is offline   Reply With Quote
Old 04-13-2007, 09:37 PM   #2
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
about the wheels, I dont know.
Unless you know some voodoo suspension tuning trick, usually having caster is good. I run around 6 degrees, Formula cars usually run 2-4. You adjust the length of the rear upper control arms to adjust camber in the rear.
use the tension rods if you want to adjust caster.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 04-13-2007, 09:48 PM   #3
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
if your rear upper control arms are OEM, there isn't much adjusting that can be made.
ladiesman8527 is offline   Reply With Quote
Old 04-13-2007, 10:02 PM   #4
tknbkthrsdy4anfg
Rucas= Rear upper control arms.
Old 04-13-2007, 10:10 PM   #5
hellllo
they are peak performance rucas i believe, i'm just reading off his mod list.
how do you adjust it? I lifted the car up and checked out everything that looks adjustable.
if i can recall they are the ones with a C shape bars?
Old 04-13-2007, 10:15 PM   #6
tknbkthrsdy4anfg
Yea, here this might help
I got this from phase 2, hope they dont mind.
You adjust it by loosening the lock nuts and threading it in to increase camber and out to decrease camber.
Old 04-13-2007, 10:27 PM   #7
hellllo
thanks alot you really helped =]
Old 04-14-2007, 01:19 AM   #8
tknbkthrsdy4anfg
No problem man, may your brother rest in peace
Old 04-15-2007, 12:11 AM   #9
the terrible one
the terrible one's Avatar
the terrible one is on a distinguished road
about your front drivers side tire sticking out.. is it toe or camber?? if its toe out/in align it buy adjusting your tie rod. its pretty simple nothing too hard.
the terrible one is offline   Reply With Quote
Old 04-15-2007, 01:28 AM   #10
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
+1 to you. Good man.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 04-15-2007, 10:45 PM   #11
DriFTech
DriFTech is making a name for him/her selfDriFTech is making a name for him/her self
Send a message via AIM to DriFTech
first off... RIP to your bro... now, are you talking bout an alignment issue with the tire sticking out such as toe? or the entire wheel sticking out like the front frame shifted of some sort?
DriFTech is offline   Reply With Quote
