Old 04-14-2007, 09:05 AM   #1
Disturbe240
Disturbe240 is on the path to ruinDisturbe240 is on the path to ruin
heater
ok this is a stupid question put i have to hask, will bypassing the heater core with a hose conecting the inlet end outlet break something:ghey: i dont whent to break anything.
is there someone runing like this her?.
thx
Disturbe240 is offline   Reply With Quote
Old 04-14-2007, 09:16 AM   #2
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
nope go for it, but explain why you want to bypass your heater core.
there are lots of people runing that set up her????????
khilgers is offline   Reply With Quote
Old 04-14-2007, 10:27 AM   #3
Disturbe240
well i dont realie need the heater core my car only runs in ther sumer, and i was in the medle of the swap wen i nodiced the the hose from the sr and ka wear not the same so i just sayd f*** it. now time to mount my custom intercooler
Old 04-14-2007, 10:43 AM   #4
g6civcx
g6civcx's Avatar
If you want to bypass the heater, you have several options:
1) On the SR, take a flexible 3/4" ID heater hose and connect the two fittings on the back of the engine near the firewall together. On the KA, do the same with a 5/8" ID hose.
2) Slice off the fittings as close to the engine as you can and weld the openings shut.
There are some critics that say #2 is not as good as #1 because it doesn't allow coolant to circulate to the head as well, but pull up a diagram of the cooling system and decide for yourself.
Pros of bypassing heater core:
a) Easier to bleed cooling system.
b) More reliability because extra connections + heater core = prone to leak, blockage, etc.
Cons of bypassing heater core:
i) ability to heat (freeze to death) and defrost (can't see shi*)
ii) heater core acts like an additional radiator if your car overheats. just turn the heater on high and blast the fan
My recommendation is for (i) and (ii) alone, you should keep the heater core, but ultimately it's your choice.
