Turbo Timer (car wont shut off)
I just installed an Apex turbo timer, wired just as the instructions say. Started the car, set it for 30 seconds and started counting down but I could not remove my key and when it was done counting down it reset and started over. My car was originally automatic and did a swap to a 5spd. I was thinking this had something to do with it, but never installed a turbo timer so I am unsure. Can anyone give me any info?
#6 |
![]() Join Date: Jan 2006
When did you do the swap? Did you wire the park release nice and secure?
I had mine electrical taped to itself and one day i was working around the console. Afterwards it wouldnt give me my key. Lazy fix, just taped it back.
Love: 89 S13 Fastback: Super stock KA24E Daily! Hate: 89 S13 Coupe: SR20 Under the knife. 87 FC: Half Bridge Turbo Monster. |
#7 | |
#8 | ||
![]() Join Date: Jul 2005
Im not a 100% positive but I think he's asking if you spliced the grey wire (the wire from the turbo timer that goes to the parking brake) to the wire that goes from the parking brake to the dash to tell the brake light to come on.
#9 |
No, the key only gets stuck when thr turbo timer is on and works normally when it is off. In other words I have to shut the timer off just to get the key out.
#10 | |
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
Christ.
Pop off your steering column surround. Find the solenoid that locks the key in place. Disconnect the spade clip that supplies it power. Once that's done (before reinstalling trim), test the system. Turn car off, REMOVE KEY, and see what happens.
#11 | |
![]() Join Date: Nov 2006
+1 ![]() Exactly what I was thinking. |
#12 |
![]() Join Date: May 2005
![]() ![]() ![]() Feedback Score: 0 reviews
Wait, I've got a very similar issue with an s13 that I swapped from auto to 5spd. The key gets stuck in the ignition after the engine is turned off, and will only release after what looks like a tiny red 'tab' is lifted. The tab I'm referring to is located behind the ignition lock, and underneath the top steering column guard.
Earlier a parking release was mentioned - maybe my wiring wasn't complete. Is there a parking release switch that must be re-wired to allow the key release button alone to let the key out? |
