Old 04-18-2007, 02:48 AM   #1
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Took the S13 to Buttonwillow Raceway for the first time!... Lots of PICS!
Last weekend I went to Buttonwillow Raceway with Speedventures to try out my S13 for the first time…
http://www.speedventures.com/
Configuration 13 which is the same configuration used for Time Attack events… On April 28th, the Redline Time Attack will be held here and it will be great to see what times the competing cars run in comparison to how me and my friends did…
Mods on the car were:
Stock KA24E – dyno - http://photos.freshalloy.com/gallery...yno+040507.jpg
Test pipe
Buddy Club Spec 2 80mm exhaust
KTS coilovers
SPL solid aluminum subframe bushings
Energy Suspension bushings
17x9 +20 5Zigen FN01-RC all around
245-40-17 Bridgestone RE01-R tires all around
Hawk Blue brake pads
Welded diff
Cost to drive my car at the event(one day) came out to $210 which included a transponder (lap timer) and lunch…
Well it all started on Saturday evening where I loaded up the car on the trailer and got on my way to Buttonwillow which is about 3 hours north on the 5 freeway from Orange County… One of my friends and I split a motel room that costed $60 for the night… We had to be at the track the next day at 8AM for the driver meeting…
Next morning we checked out early and made it to the track…
A couple of our friends rented out some of the garages so we basically had the entire paddock to chill at…
Some pics of the car…
And some pics of Buttonwillow Raceway…
This is where you enter the track… The way it works is that you are able to go on the track when it is your “run group”… Run group is determined by whatever skill level you say you are… So beginners run with beginners and advanced with advanced… I ran in the beginner/intermediate group where the rules are that you can only pass on the straightaways…
And here is what the transponder looks like… It records the track time each time as you pass the start/finish line… After each run, they print the times and post them for everyone to see and analyze…
I ran in 4 of the 5 sessions with my best time being 2:22 … Not bad for first time at Buttonwillow, one of the lowest HP cars there, untuned suspension settings, and me being a beginner driver…
The car took two laps to warm up the brakes and tires with the first two sessions of me learning the course… Learning the elevation changes, cones that mark where you should brake and clip the apexs, what gears to use in what area, and how well the car brakes and grips…
On the second session I made the mistake of pushing the car on the second lap and ended up going off course pretty bad at Lost Hill… I believe I was going too fast and too straight over Lost Hill which you have to go through blind because it falls off to the right and the car understeered off the track…
For the third session I slowed down to learn the lines better and sped up with each lap I went…
The final session I started first in line… After the warm up lap, I let a Miata pass me and began to chase him for the next few laps… By the 5th lap, my car(and the driver) had warmed up very well and the car was gaining ground on the Miata… No other car had passed me except for the Miata… Going into Riverside, the Miata gave me the OK to pass him and I tried to pass on the right and ended up not being able to make the long right and the rear of the car rotated around clockwise… I did a 540* into the dirt and ended up flat spotting the two front tires… I shouldn’t have tried to pass the Miata without any HP to pass him and should have waited for the straightaway… Very scary and when the car went off course, the dirt hit the windshield and blinded my view…
After I got back onto the track, I was running through the esses and something fell out of the car so I pulled off the course… The yellow flag came out and the emergency crew came to help me find out what happened… We walked out onto the track and found part of my clutch fan on the track… We opened my hood and found a mess of the radiator, clutch fan, fan shroud, and water pump… The car was pulled off the track by the tow truck…
Here is what the damage came out to…
I guess this is what happens when you push a 225K motor at the track…
I turned the car on to get it on the trailer which was at the end of the day anyways… The 2 tires I will have to replace kinda sucks but at least the car was not damaged… Tires are easier to replace than bodywork…
Out of 101 cars I was one of the 8 lowest HP cars out there… Same for my straightaway trap speed… It was funny that most of the S2000s would go through three gears on the main straight where as I would go through 3rd gear the entire way… And with the Buddy Club exhaust it was one really long and loud straight line… My car was one of the loudest cars there which was fun except for the fact that I couldn’t hear when someone was trying to talk to me when riding passenger in the car…
Here are my friend’s cars and a quick overview of their times and modifications… My goal was to hit faster than 2:30 which I hit in my first lap… Through the day I ended up with a 2:22 which was consistent with many of the stock $30K sports cars out there…
I believe I would be able to hit 2:15 with this exact setup and a much more experienced driver or a mediocre driver with 200WHP… 92% of the cars running faster than 2:10 were running race tires and only 2 cars ran faster than 2:00… Average HP of the cars running street tires was 247… Average time of all the S2000s was 2:12…
Daryl’s S2000… 2:06
KW two way coilovers
Race tires
Stock engine
Exhaust
Voltex wing
Some videos of Daryl’s runs…
http://video.maxrev.net/Daryl/
Kel’s S2000… 2:01 with Kel driving it, 1:59 with Rob driving it
Similar to Daryl’s… ASM fenders
Evasive Motorsport’s S2000… 2:09 with Mike driving it, 1:57 with Rob driving it
J’s racing custom valved coilovers
255 race tires all around
Voltex wing
Stock engine
Exhaust
Fastest lap time of the weekend… Even faster than the slicked up brand new Z06s out there…
Rob’s S2000… low 2 minute range…
Similar setup to Daryl’s… He is one of the best S2000 drivers out there and drove Mike and Kel’s cars to the two fastest times of the weekend… Check his website out…
http://www.maxrev.net/
Nasif’s Civic Si… 2:23
Stock with Tein coilovers
Albert’s Audi TT… 2:16
Turbo and AWD model
Stock except for 225 Bridgestone RE01-R tires
Jon’s S13… 2:20
Stock engine
Tein basic coilovers
Falken Azenis 205 tires
2 way LSD
HKS exhaust
He had problems with a 5K rev limiter the entire day…
So that was my first time with this car at the track… I’ll be back and will keep you updated on my progress… Next event for me will be at the end of May at Streets of Willow…
Until then I have a todo list of things to take care of before then that is taped to the windshield…
Here is a couple of videos:
Cars entering the track…
http://nitinj.com/Images/240SX2/Butt...w take off.AVI
Cars flying by the start/finish line…
http://nitinj.com/Images/240SX2/Butt...low fly by.AVI
My first lap around Buttonwillow taped from the Si… Notice the flame out of the exhaust at 1:21…
http://nitinj.com/Images/240SX2/Butt... S13 chase.AVI
And the Youtube version of that video at crappy resolution…
http://www.youtube.com/watch?v=pYQUGnxrBKE
Nikeboy355 is offline   Reply With Quote
Old 04-18-2007, 03:00 AM   #2
Dousan_PG
Dousan_PG's Avatar
looks like fun
sucks bout the water pump but meh
still a fun day
i LOOOOVE buttonwillow
off ramp! its the best!!!
Aaron
Pink GodziRa
Old 04-18-2007, 03:02 AM   #3
JDMClifford
JDMClifford's Avatar
JDMClifford is an unknown quantity at this point
looks like you had a blast. i blew my motor from a clutch fan. sooo be carefull ;P
Parking lot pimping
JDMClifford is offline   Reply With Quote
Old 04-18-2007, 03:13 AM   #4
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Im glad you had fun. I just cant wait till i have money to bring my car to the track and tear it up.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 04-18-2007, 06:04 AM   #5
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Sexy exhaust nikeboy, love the specII. Nice car btw
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 04-18-2007, 06:12 AM   #6
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
looks like you had fun the closest thing that we have to a track in NJ would only be gymkhana.. unless i felt like driving 6 hrs and paying $300 for not so much track time at all..
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 04-18-2007, 06:28 AM   #7
Chez
Chez is making his/her stupidity well-knownChez is making his/her stupidity well-knownChez is making his/her stupidity well-known
So in cali you can race wheel to wheel with just a drivers license and a helmet!? They make it so easy out there in ct I have to get a racing license, cage my car spend about $5k for those things and then its 400 bucks per event at the track near my house. Congrats on your first time at the track im really jealous. - Chez
Originally Posted by ixfxi
Stick with high quality italian made rotors, and you dont have a problem. Go with cheap, made in china bullshit.. and like most of anything made in china, you end up with fried rice.
Chez is offline   Reply With Quote
Old 04-18-2007, 07:40 AM   #8
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Nice dude, would love to be able to drive that track.
New water pump and some electric fans and you'll be good to go!! rockin the sohc
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 04-18-2007, 08:07 AM   #9
swwifty
swwifty is an unknown quantity at this point
great writeup.
do you guys have instructors?
also, got any videos of this guy rob driving the s2ks? I'm curious to see some. I watched Daryl's onboard videos.
swwifty is offline   Reply With Quote
Old 04-18-2007, 08:27 AM   #10
Nikeboy355
Nikeboy355's Avatar
This isn't considered wheel to wheel because you aren't allowed to be aggressive in passing other cars... If you are, the corner workers will black flag you and you will eventually be pulled off the course... The point of the event is to get clocked with faster and faster times...
With Speedventures beginner group for $30 more an instructor will ride with you in the car and give you their criticism... That day they didn't have a beginner group but they did the day before... The group I was in was beginner intermediate...
Let me see if anyone has them... There were cameras everywhere... I also have a 900MB video of my final run from the inside of my car that I am working to cut down in size so I can put it up here...
Old 04-18-2007, 08:33 AM   #11
exitspeed
aWingThing.com
exitspeed's Avatar
Looks like you had fun, minus the water pump part.
Good luck on your next one!
Old 04-18-2007, 09:17 AM   #12
OBEEWON
OBEEWON's Avatar
Man. If I had a trailor and a truck I would be at every event in the NE, Looks like a nice weekend. Race tires cut times like madness.
Old 04-18-2007, 09:33 AM   #13
myriad
myriad is an unknown quantity at this point
Send a message via AIM to myriad
Dood, friggin' thumbs up on tracking 225K. I am gunna take mine out when school finally gets out - if only there were awesome tracks like that in Indy.
225K+ Motor Members UNITE!
Woot.
: S14 :
myriad is offline   Reply With Quote
Old 04-18-2007, 09:51 AM   #14
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Props for running the single cam. I can't wait till I do my first event.
SDS13COUPE is offline   Reply With Quote
Old 04-18-2007, 10:28 AM   #15
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
nice man, i love the fireball on the sohc
got a question, do passengers pay for them to be in the car with you, (for insurance)?
markyboi is offline   Reply With Quote
Old 04-18-2007, 10:30 AM   #16
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
for some reason i thought you had a dohc rebuilt...
did your tires rub your fenders with your set up? (since you don't have gangsta camber with fat tires and low offset rims)
nice write up
Wei240 is offline   Reply With Quote
Old 04-18-2007, 11:23 AM   #17
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Wow those times with a KA are pretty impressive, especially compared to the S2k's out there.
JaeTea is offline   Reply With Quote
Old 04-18-2007, 12:32 PM   #18
steve shadows
steve shadows's Avatar
Don't blame the car.
In all honesty didn't you take the whole thing apart and put it back together before the event?
I eliminate clutch fans on track cars (sure the clutch fan cools better in many tests), but I dont have overheating issues with my tiny little crappy autozone fan on my KA car.
sorry to hear about that.
Like Me on FaceBook !
Old 04-18-2007, 12:41 PM   #19
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
your new s13 looks like a replica of your previous car looks good man!
jdm538 is offline   Reply With Quote
Old 04-18-2007, 12:51 PM   #20
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
+1, nice job. always cool to hear peps getting into racing there cars fo real. get that car back together and get back out there. Congrats
burgy240 is offline   Reply With Quote
Old 04-18-2007, 12:54 PM   #21
SNC240SX
SNC240SX's Avatar
SNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfectionSNC240SX is close to perfection
Looks like you had a good time. Buttonwillow looks like an awesome track.
SNC240SX is offline   Reply With Quote
Old 04-18-2007, 01:16 PM   #22
ranger240
ranger240's Avatar
ranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the rough
+1 on a real clean car... and for 255k at a track.. insane
ranger240 is offline   Reply With Quote
Old 04-18-2007, 02:33 PM   #23
OptionZero
OptionZero's Avatar
glad you had fun and stepped up to drive, unlike many zilvians
for some reason i could never get into a rhythm at buttonwillow, i can't explain it
at infineon, taking the proper line means every corner leads you to the next corner, and if you hit the apex you are in perfect position to hit the next one
at buttonwillow...maybe i just never really memorized the configuration, bleh
anyways, yeah, keep hittin the track, bro, then branch out and u can compare different layouts
OptionZero is offline   Reply With Quote
Old 04-18-2007, 04:19 PM   #24
ZodiacSR
ZodiacSR is making a name for him/her selfZodiacSR is making a name for him/her selfZodiacSR is making a name for him/her self
Nit, who gave you consent to post my car on the web?? HAHAHA.. Just kidding! 5K redline all day sucks ass, it won't happen again now that the 5th gear sensor is in the trash, LOL. You did good out there for your first time!
We were the only 2 240's out there, we need more of you guys out on the track!
Buttonwillow Config#13 is my favorite layout. I'll try to get my in car video up as well if you guys are interested
SPV Jon
ZodiacSR is offline   Reply With Quote
Old 04-18-2007, 05:13 PM   #25
Nikeboy355
Nikeboy355's Avatar
Hey Jon... Glad you found my post... I'm a documenting maniac so anyone and anything within 100 feet will end up on my refurbished Canon digital camera...
I went for a ride in Jon's car and his car was a lot of "fun" to ride in... The car, piloted by Jon, just glides through the entire course without being jerky or off balance... I think it might be time for a little more power or a little more tire...
Jon was also in the car with me when I ate it at Lost Hill... We hit the dirt pretty hard and Jon had to smoke half a pack of cigarettes before he could talk again... Just before we went on that run, we also noticed that there was no lap belt on the passenger side... Jon, I put some extra long zip ties in the glove box for next time so you can strap to the seat... haha...
Nope... the car doesn't even have to be registered or insured... You break you deal with it... Including yourself...
I do but I couldn't finish it for this event... It's going in as we speak...
Not at all... I used an Eastwood fender roller and gained a bunch of clearance... I rolled them until they were as flat as possible... Camber was set at -2.5* front and -2* in the back...
Yeah, I thought about that but there is only one way to put on a clutch fan... You really can't mess that up... And everything was still bolted together when it fell out... What happened was that something got the fan off balanced, caught on something (belt or shroud) and ripped out of the water pump... Probably just an old clutch fan with a lot of play in it...
Old 04-18-2007, 06:10 PM   #26
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
thats awesome, i've been there but have never driven there. now seeing you do it i want to, i have a basically stock 225k sohc too....you're my new hero...lol, but yeah nice runs.
C. Senor is offline   Reply With Quote
Old 04-18-2007, 06:17 PM   #27
Farzam
Farzam's Avatar
I'm glad I read this thread.
Great way to learn experiences, and it's a good reminder for everyone to doublecheck your shit out before racing it.
Farzam is offline   Reply With Quote
Old 04-18-2007, 06:47 PM   #28
vincem
vincem is an unknown quantity at this point
nice video! is it your car that sounds loud in the video, or is it the s2000 whose recording?
vincem is offline   Reply With Quote
Old 04-18-2007, 07:07 PM   #29
adrians_s13
adrians_s13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
nice pics! Looks like you had a blast!
@adrianfromthecastle
Old 04-18-2007, 08:25 PM   #30
swift_style
swift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the roughswift_style is a jewel in the rough
man, that looks fun!! I've always wanted to autoX more than drifting somehow.
swift_style is offline   Reply With Quote
