Old 04-18-2007, 04:44 AM   #1
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
Flywheel cover?
Ok, this is weird. While towing my s13, i noticed that i could see my flywheel, where the tranny bellhousing ataches to the engine....?!?!?!?
is this supposed to be exposed? i feel like any road debris could get up there and mess some stuff up.
Please only respond if you know. No speculation. I know common sense tells me there should be a cover there.
Im going to look at my FSM and take a picture. ill post it up here later today.
thank you
CoasTek240 is offline   Reply With Quote
Old 04-18-2007, 06:25 AM   #2
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
have a picture of what you mean?? the only way u should be able to see your flywheel is if the trans is unbolted sitting in front of you :P and through the starter mount..
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 04-18-2007, 07:06 AM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
ka or sr
789101112
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 04-18-2007, 07:11 AM   #4
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
Definitely should not be exposed on any engine because, as you mentioned, road debris could get in there and ruin your day. That's why the hole that your clutch fork sticks out from has a dust boot on it.
DJ_Sunrise was right, only if you tranny is unbolted or if the starter is off.
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 04-18-2007, 08:55 AM   #5
projectRDM
projectRDM's Avatar
There's a backing plate that sits against the block, behind the flywheel. You don't have it apparently.
Old 04-18-2007, 10:00 AM   #6
Sileighty_85
Sileighty_85's Avatar
It must be an A/T if it is then yes there is a plate that bolts on to there.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-18-2007, 10:05 AM   #7
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
even if its a manual tranny theres still a plate that goes behind the flywheel. i know because i forgot to put mine back on after i had the flywheel resurfaced and put in a new clutch. i didnt realize until i put the tranny back on. luckily the motor and tranny were out of the car so it wasnt too much trouble to take everything back off and put the plate in place.
EDIT: heres a picture for the OP
i got the picture from an ebay auction and its kinda shitty. the plate is a few mm's thick. you get the idea.
ladiesman8527 is offline   Reply With Quote
Old 04-18-2007, 10:14 AM   #8
toledo240
toledo240's Avatar
toledo240 has a little shameless behavior in the past
i know what your talking about, i dont have it, i just made somethin out of sheet middle to cover the whole and havent had a problem, but yes cover that thing
toledo240 is offline   Reply With Quote
Old 04-18-2007, 10:36 AM   #9
!Zar!
!Zar!'s Avatar
I have a car that has the bottom of the flywheel exposed.
I could care less.
No problems and the car has been running strong for ages.
Old 04-18-2007, 10:21 PM   #10
CoasTek240
CoasTek240's Avatar
I could care less.
haha i knew it. i have been driving it for at least a couple monthes with out it. i want to put an OEm one back on.
anyone care to point me in the direction of a good place to order that. the junkyards around my area blow.
thanks for all the input
Old 04-19-2007, 07:07 AM   #11
ladiesman8527
what motor is this for? the picture i got was from an auction for an SR20DET backing plate. either way, im sure ebay would have one.
Old 04-19-2007, 09:51 PM   #12
CoasTek240
CoasTek240's Avatar
nice its for an s14 Ka24de. The block is a built AMS performance block. its in an s13 with an s13 tranny.
Old 04-19-2007, 09:52 PM   #13
projectRDM
projectRDM's Avatar
All KAs use the same backing plate, 91-98.
Old 04-19-2007, 11:13 PM   #14
Eddie@Performance
Eddie@Performance's Avatar
Eddie@Performance is making a name for him/her selfEddie@Performance is making a name for him/her self
Send a message via AIM to Eddie@Performance
Its a backing plate that covers the lower half of the engine block to trans bell. There is supposed to be a gold color steel plate that covers it. I guess if you dont have it, it functions as a clutch cooler also lol.
PERFORMANCE NISSAN IN DUARTE
My Direct Line 626-739-1968 or TOLL FREE 1-866-211-7389 For All Your Nissan Parts Needs!
1434 Buena Vista St
Duarte, CA 91010
Where the 210 & 605 Freeways meet, Buena Vista Exit!
My Garage:
1990 Nissan 300ZX Twin-Turbo (modded weekend car)
2008 Suzuki GSX-R750 (Race/Weekend bike)
2003 Toyota 4Runner V8 Limited (Daily stock and boring)
2002 Honda VFR800 Interceptor V-TEC (Sport Touring Bike)
Eddie@Performance is offline   Reply With Quote
Old 04-19-2007, 11:21 PM   #15
Eddie@Performance
I know this pic is for a auto trans but you get the picture, its the part marked in red:
1434 Buena Vista St
Duarte, CA 91010
My Garage:
Old 04-22-2007, 10:22 PM   #16
CoasTek240
CoasTek240's Avatar
Eddie@Performance
Thanks. You went above telling me to use the search button and posted some good info.
Russ you happen to have one of these plates sitting around.... I'd rather you ship it to me Vs. driving down to GA.
can you help?
Old 04-23-2007, 09:11 AM   #17
projectRDM
projectRDM's Avatar
As soon as I have time to pull a transmission I'll have one. Maybe late next week?
Old 04-23-2007, 09:59 PM   #18
CoasTek240
CoasTek240's Avatar
Thanks Russ, pm sent.
