Old 04-18-2007, 01:33 PM   #1
cleantune
cleantune is on the path to ruincleantune is on the path to ruincleantune is on the path to ruin
S14 Fuel pump fuse
I wanted to add a switch to turn the fuel pump on and off in the s14 but, I am having trouble locating the fuse for the fuel pump. I looked on the fuse box cover and it is NOT written on top ( like the s13). I would appreciate any help i can get. Thanks
cleantune is offline   Reply With Quote
Old 04-18-2007, 01:34 PM   #2
cleantune
the car is a 98 s14
Old 04-18-2007, 01:39 PM   #3
projectRDM
projectRDM's Avatar
You don't put a switch on the power side, do the ECU trigger, black/pink just like every other Schassis. Found at the ECU, F3 plug, or the relay.
Old 04-18-2007, 01:39 PM   #4
ag69
ag69's Avatar
ag69 is making his/her stupidity well-knownag69 is making his/her stupidity well-knownag69 is making his/her stupidity well-known
from what i was told by wiring specialties.....you got to follow a purple and black wire to the the ecu and the relay is on the driver side kick panel. so you can put switches there.
"That's Life"
ag69 is offline   Reply With Quote
Old 04-18-2007, 01:42 PM   #5
projectRDM
projectRDM's Avatar
You were told wrong. There is no purple/black wire anywhere in the car.
Old 04-18-2007, 02:08 PM   #6
cleantune
I dont want to be "spoonfed" any answers but, Once i locate the black / pink wires do you have any suggestions about wiring the switch? I was planning on locating the fuse and running it like the diagram below.
Fuse (Optional LED)------lllll
O---ll ll-------------------lllll Switch
O--------------------------lllll
^ original fuse sockets
Old 04-18-2007, 03:53 PM   #7
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
if you want to do a switch on the fuse... it in the engine bay fuse box.
if you want to wire it from the ecu... its in the passenger side kick panel. black/pink wire.
i got that.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 04-18-2007, 03:53 PM   #8
Addicted2Kouki
go on nico... they have a couple tutorials there.
Old 04-18-2007, 04:47 PM   #9
cleantune
I checked out the teck section at nico and I came up with the fuse wiring but the fuse is no not labeled in the cover of the fuse box.
Old 04-19-2007, 09:24 AM   #10
projectRDM
projectRDM's Avatar
Do NOT put a switch at the fuse. NICO is fucking retarded, don't even begin to look through that shit.
The black/pink is a low current ground trigger so there's no need to fuse it. A SPST switch will do fine. Pull the relay, clip it the trigger wire, and run each side to the switch. Done and done.
