Old 04-26-2007, 02:58 PM   #1
hellllo
hellllo can only hope to improve
Quick Alignment Question
I'm getting new and bigger/wider wheels in about a week or 2. Would it matter if i got my car aligned with stockies rather than the new wheels? I just dont trust any shop with brand new wheels.
Thanks
hellllo is offline   Reply With Quote
Old 04-26-2007, 03:11 PM   #2
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
Nope
it would not
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
Originally Posted by Brian
No it isn't
This is "cool stickers"
not"let's make our car look like a pile of shit and dead babies"
Ian is offline   Reply With Quote
Old 04-26-2007, 03:16 PM   #3
250sxdet
250sxdet will become famous soon enough250sxdet will become famous soon enough250sxdet will become famous soon enough
Make sure you lower your car the desired height first. Test fit the new wheels on then get it alligned.
250sxdet is offline   Reply With Quote
Old 04-26-2007, 03:15 PM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
I would think it would, different tires, different heights, different tire wear, different air pressures, etc... Its going to be minor differences but it could.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 04-26-2007, 03:24 PM   #5
Ian
Yeah, once your suspension is set, it's set...the wheels aren't gonna change jack shit.
Someone correct me if i'm wrong but as far as I know, it won't. Maybe to a nominal degree but nothing noteworthy.
I mean, this isn't Formula 1 here...
I think BH said it once..."handling? What the fuck do I need handling for? I'm sliding all over the place on the track, I don't need handling"
Team Pterodactyl
SHARK ATTACK!!!
LookOutDrift
No it isn't
Old 04-26-2007, 09:17 PM   #6
Infamax
Infamax's Avatar
Infamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enough
Since you're gonna upgrade to a wider tire/wheel, I would test fit them first before you have the car aligned. If your wheel were to rub and require you to change height or camber, then you'd have to re-align it.
Infamax is offline   Reply With Quote
Old 04-26-2007, 10:03 PM   #7
SilentSamurai8
SilentSamurai8's Avatar
SilentSamurai8 will become famous soon enoughSilentSamurai8 will become famous soon enoughSilentSamurai8 will become famous soon enoughSilentSamurai8 will become famous soon enough
I have to tell people that everyday at work..."taking your wheels off and putting them back on will not change your alignment, or will it make your car pull or push out of no where...I assure u."
However in this case you would want to test fit them first and make any/all adjustments then. Different/more weight and air pressure can make VERY slight changes. Not enough to notice at this level though.
SilentSamurai8 is offline   Reply With Quote
Old 04-26-2007, 10:38 PM   #8
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
I would not bring my car to an alignment shop with the rims on.
Find one that will pay for the rims if they damage it. Nobody around here would even think of it
KA-T_240 is offline   Reply With Quote
Old 04-27-2007, 12:20 AM   #9
ixfxi
Guest
Posts: n/a
No difference at all.
Second, alignment shops have never scratched ANY of my wheels. Only tire installs risk that.
