Old 05-08-2007, 02:20 AM   #1
heavy1metal
heavy1metal is an unknown quantity at this point
questions about pistons and bearings
I need to buy Rod bearings and Main crank bearings. They are for a kouki S14 Blacktop. Can someone recommend a good online vender that sells them.
From what I understand the S13 and S14 bottem end are the same. So I will be using the pistons and rods and crankshaft from a S13 and putting it into my S14 block. correct me if I am wrong so I can save alot of time and money
heavy1metal is offline   Reply With Quote
Old 05-08-2007, 04:19 AM   #2
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
91-99 nissan sentra 2.0 use the same bearings as a s13 and s14 SR
sunnys14 is offline   Reply With Quote
Old 05-08-2007, 06:54 AM   #3
Wahl 136
Wahl 136's Avatar
Wahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to allWahl 136 is a name known to all
What he said, you can get them on Ebay for around $75 shipped. That's where I got mine.
Wahl 136 is offline   Reply With Quote
Old 05-08-2007, 07:32 AM   #4
Sileighty_85
Sileighty_85's Avatar
www.RHDjapan.com I orederd some Tomei Micro Finished Con-Rod Bearings and the Nismo Main Cranks
Internals on the RT& BT should be the same but the Oil Pump and Water Pump are differnt
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-08-2007, 07:15 PM   #5
heavy1metal
Now any idea where I can get Crank cap bolts and also rod bolts?
Old 05-09-2007, 10:10 AM   #6
Sileighty_85
http://shop.hybridynamics.com/index....TS&Category=53
www.Hybridynamics.com <--they have Pulasr GTI-R Crank Bolts 22% Stronger over stock for 40 Bucks!! and APR Hardwear
後輪駆動車1番
1986 SR86 - 200ish
