SR trans help
I searched the forums for a problem similar to this but couldn't find anything related to this
I got a s13 redtop and I noticed that I have some leakage going on right under the shifter kind of by the driveshaft.
What are the name of the seals around that area that I should change and where can I find them? Do you guys have part numbers that I can use to get them? my friend told me to change the trans seal connecting to the driveshaft. Anything else I should change while I'm at it? could it be something else?
my clutch started acting up saturday night while going home. Instead of grabbing halfway through releasing the pedal, it now grabs really low. like an inch from the bottom while releasing the pedal. I tweaked the adjusment screw on the clutch pedal and its a little better now, but its nowhere near what it normally feels like. I have a lot of play on the clutch now.
Could it be related to the fact that my trans is leaking and probably doesn't have the proper amount of fluid in there? I'ma fill the trans with some fluid tomorrow and see if it helps.
I doubt its my master or slave cylinder but at this point I'm open to all ideas/input cuz the clutch fluid is clean and when I press on the pedal it seems like the slave is pushing all the way out and coming back all the way. I'ma fill the trans with some fluid tomorrow and see if it helps
any help would be appreciated.
thx guys
