Old 05-08-2007, 10:07 AM   #1
ApexRK
ApexRK will become famous soon enoughApexRK will become famous soon enoughApexRK will become famous soon enoughApexRK will become famous soon enough
SR S14 SR20 problems under boost
Car is a 97 Kouki with a zenki S14 SR20, only mods are walbro pump, fmic and turboback exhaust.
When getting into the boost the car almost bucks a bit and feels very irractic on power, once its at full boost 8-10psi I am getting what feels like the timing being pulled and then advancing giving that on/off feeling. Then sometimes it just doesn't want to go under WOT just bogs on the power.
I did have a big boost leak, but its fixed and still the problem is there. I don't have any logging software to monitor anything so I'm at a loss as to what it could be, any ideas?
Yes I did search, but nothing answered by question.
ApexRK is offline   Reply With Quote
Old 05-08-2007, 10:12 AM   #2
wookieballa
wookieballa is a well-known jackass
try the starter fluid trick, spraying it on your piping connections, you may still have a boost leak, check into the starter fluid first, as it may damage your piping finish, not sure. does it have the correct mafs? and is it in safe mode does it idle ok? i would assume its a boost leak somewhere.
wookieballa is offline   Reply With Quote
Old 05-08-2007, 10:25 AM   #3
chrisman2k
chrisman2k's Avatar
chrisman2k is an unknown quantity at this point
Send a message via AIM to chrisman2k Send a message via MSN to chrisman2k
I have the exact same problem on my 98 with a rb25 in it. With me though, anything over 8-9psi, it starts pulling timing also. My solution, put better gas in it. I was told by a couple of people that since I have a stock setup out of japan, our 91 oct. gas is not enough. They said that over in japan, premium gas is 100 oct. so I tried putting some in and wala, no more issues.
I also asked about several friends I have that have stock SR setups that are boosting way more, and they said that for the s13 sr20's they have a smaller turbo and that they don't flow as much as the later sr's and rb25's.
Hope this helps
If anybody knows different, or if the people I talked to were wrong, please correct me!
EDIT: I don't have boost leaks, already checked and corrected
chrisman2k is offline   Reply With Quote
Old 05-08-2007, 11:22 AM   #4
ApexRK
It is using the stock SR maf so that is not the problem, plus normal driving is just fine, cruising, light/moderate acceleration is great, smooth idle so I doubt anythign to do with a MAF. This has boost leak written all over it, but there are no leaks last I checked.
I am running 94oct so gas is also not an issue.
Unless someone has anything I else to suggest I'm going to try another boost leak test to make sure another one hasn't started.
Old 05-08-2007, 11:30 AM   #5
wookieballa
check your BOV is it blowing by a little, also check your exhaust mani, it may be loose, causing issues, and your maf may be bad, grab a SOHC maf from the junk yard, and try that, could be just having issues with that. good luck. (sorry to repost, but i just thought of these issues)
Old 05-08-2007, 12:05 PM   #6
ApexRK
BOV is good no leaks at all.
exhaust mani, no leaks cause if there was I would know by now.
MAF could be it so I'll see if I can get my hands on a spare one. Tell me does a KA maf work on a SR, harness snaps on too? I honestly don't know.
Old 05-08-2007, 01:04 PM   #7
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
s14 ka is different, there are 2 kinds of s13', both will work if you have the pig tails, there's the 4 pin plug that's really a 3 pin plug, then there's the 3 pin plug that doesn't have the naked extra pin. gl
Z U L8R is offline   Reply With Quote
Old 05-08-2007, 01:22 PM   #8
mr_240sx
mr_240sx's Avatar
Ryan, if you want i can bring my s14 sr maf with me when i come over tonight and we can test out to see if the problem is maf related. let me know if you want me to do that.
Mats
mr_240sx is offline   Reply With Quote
Old 05-08-2007, 01:37 PM   #9
wookieballa
my bad, i didnt see that it was an s14 sr, you can use the sohc mafs (ka) for the s13 sr's, but not the s14. they are different. so you will need an s14 sr mafs to try, and if thats bad, you may have to just go with a z32 mafs, and SAFC or some other piggy back type air/fuel computer to adjust for the mafs change.
Old 05-08-2007, 01:39 PM   #10
ApexRK
Mats
Shit I didn't even think to ask you Mats, ya definetly bring it with you that will be a huge help.
Old 05-08-2007, 06:16 PM   #11
ApexRK
So it seems I have solved the problem, but not without some question. A very knowledgable friend of mine suggested playing with the CAS which I did. I already had the timing set at 15degrees as per the FSM procedure, but the CAS was fully to one end of the adjustment range to get there, full retarded. So I moved it more in the middle, drove around and the car was ALIVE!, came back home to check the timing with the light and after adjusting it again I ended up having the CAS set where the car ran great, but it was at 24degree base timing?
Why is that? in order to get the car to run normal and have the CAS positioned in the middle the timing is 24degrees?? can someone help me on that? I know 15degrees is the factory spec and its just a suggestion, but 24 is far off that.
Old 05-08-2007, 10:23 PM   #12
mr_240sx
mr_240sx's Avatar
tks for all the help tonight Ryan..... good to see your sr running good!
Old 05-09-2007, 07:27 AM   #13
ApexRK
no problem mats
started a new thread on the timing issue since its a new problem now http://www.zilvia.net/f/showthread.p...92#post1368092
