Old 05-11-2007, 06:24 PM   #1
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
Damn it. More KA woes won't run
Now I will clarify from the beginning that this is my fault but it is something that is needed to be delt with. I found out my oil leak was coming from my timing cover. Sooo I pulled the valve cover off and the cover w/o marking the distributer and pulling it out first. I put it back together and it doesn't start. So I messed with the distributer for hours until I decided to pull the valve cover off to make sure it was at TDC on the compression stroke and not exhaust. The rotor button was in the right place and everything was torqued and plugged back in. I cranked it and it ran shitty and died. I've tried everything I could think of and nothing has worked. Its like its being flooded out. At one point I had it idling for a few minutes and as soon as I touched the pedal, it dies. Please help me out I'm tired of driving my gas hog truck.
Boost Coming soon...
twofortyrida1388 is offline   Reply With Quote
Old 05-11-2007, 08:06 PM   #2
twofortyrida1388
Could I have done something to the CPS? I did get a code 11. After I erased it and TRIED cranking it again it didn't come back.
Old 05-12-2007, 09:00 PM   #3
aznpoopy
aznpoopy's Avatar
probably still a timing issue.
it can be tricky if you haven't done it before.
search for resetting timing on any 240 forum for more info, or get a FSM and follow the procedure. installing the distributor is a little finnicky since it rotates when you slide it in.
aznpoopy is offline   Reply With Quote
Old 05-18-2007, 11:04 AM   #4
twofortyrida1388
Thanks man. I still don't have it running.
Old 05-29-2007, 08:34 PM   #5
twofortyrida1388
I put a new fuel filter and pump in and now I'm getting 37/40 psi idling. I still can't drive it because now it won't rev past 3900 and when I do get it there it backfires. I made sure it was tdc on compression and mad sure the the rotor button was pointed at the #1 wire terminal. But the only way it runs somewhat smooth is if the distributor is turned all the way to the right and still be able to put the bolts in. Its not throwing codes. Idle is very smooth, it sits right on 700 and I cant even see it lope or move at all. The only way it will rev is if I ease on throttle. If I try to punch it, it really backfiers and acts stupid. How can I see it timing if absolutley flawless? Oh and i can here a whirling noise coming from crank at about 2000/2500 rpm but then again my crank seal is bad. It doesnt vibrate or shake either. What could this be?
Old 05-30-2007, 12:05 AM   #6
beetlejuice
beetlejuice's Avatar
beetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura aboutbeetlejuice has a spectacular aura about
Could be your MAF (usually the culprit for motors that don't like to rev).
You can try cleaning your MAF. Might be some buildup on the element.
Or try swapping your MAF with a friend.
Sometimes the connections can get screwy. Unplug, then plug in your MAF.
For timing, go to ka-t.org. There's a tech article over there that makes it easy. I used it when installing a new distributor on my s13.
jollydwarf.com
beetlejuice is offline   Reply With Quote
Old 05-30-2007, 12:06 AM   #7
beetlejuice
Also, check your throttle position sensor (TPS).
jollydwarf.com
Old 05-30-2007, 12:14 AM   #8
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
Fix the m 'fer SHIT!!!!
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 05-30-2007, 12:14 AM   #9
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
the first car the KA was put in was not a truck! Anyway.... can't help you on that issue good luck.
Old 05-30-2007, 11:59 AM   #10
twofortyrida1388
The truck I'm driving has nothing to do with my ka. How do I "check" tps? I pulled the maf off a dohc with 160000miles on it and it is clean as a whistle. Still chromey looking on inside.
Old 05-30-2007, 12:29 PM   #11
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Sounds like your timing is still off. Are you getting codes anymore?
You check the TPS by measuring it's resistance at closed & WOT, the FSM has the #s to check against. You can also measure the voltage signal it produces at idle, I think it should be .5v at idle.
MELLO*SOS is offline   Reply With Quote
Old 05-30-2007, 12:40 PM   #12
twofortyrida1388
No, no more codes. I dont have the fsm either.
Old 05-30-2007, 01:21 PM   #13
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
http://phatg20.net/modules.php?name=...ownload&cid=66
Get the 1994 fsm. Looks like it's a rar, you'll need www.winrar.com to uncompress it.
So your engine fires up, idles rough and dies if you touch the throttle? Or is it another issue now
Old 05-30-2007, 02:41 PM   #14
twofortyrida1388
Before it would idle rough and die but after I put in a homemade fuel pressure gauge I was only getting about 19psi idle so I then put in a new fuel pump and got about 38 idle and it ran. But then it was backfiring and wouldn't rev past 4k. I just went ouside and played with the rotor button after someone pointed out the markings on crank an bam, she runs perfect. Cranked on first turnover and I can stomp it and it barely boggs like before and revs much better. I still think my egr is leaking but I know there is a vac leak in back of intake mani because when I compression tested it I could hear a hissing back there. Oh but now my crank seal went out because after revving it for a while I had a puddle of oil the size of a shoe sole under crank. I think the crank has been the source for my oil leak this whole time as well.
Old 05-30-2007, 02:50 PM   #15
nka203
nka203 is on a distinguished road
i had the same problem couldn't get my car to run for 2 days, it would start, ran shitty and died within a minute. it was very simple, i just pulled the distributor out, turned it slightly and put back in, and voila it ran perfect. it's probably a tooth or 2 off.
nka203 is offline   Reply With Quote
Old 05-30-2007, 02:53 PM   #16
twofortyrida1388
Its fixed now after the crank seal goes in.
