Old 05-26-2007, 10:23 AM   #1
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
is this normal?
bought a set of some used pistons with rods...does this look alright??
benefitx is offline   Reply With Quote
Old 05-26-2007, 10:41 AM   #2
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
it looks like detonation. definatly not a good thing.
sr20boostn20 is offline   Reply With Quote
Old 05-26-2007, 10:44 AM   #3
benefitx
thats what i thought...
Old 05-26-2007, 11:02 AM   #4
benefitx
are they usable or what??
Old 05-26-2007, 11:20 AM   #5
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Yeah it looks like detonation. That piston was really close to losing its ringland completely. I would say that they shouldnt be reused. There is obvious pitting and erosion on the surface and around the ring land area. I would budget for new pistons. For moderate power rebuild, new stock pistons (54C) should be just fine.
Big Bronze Rim is offline   Reply With Quote
Old 05-26-2007, 11:26 AM   #6
benefitx
damn........
Old 05-26-2007, 11:32 AM   #7
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
how much did you pay?
what was the sellers description of the pistons.
s13gold is offline   Reply With Quote
Old 05-26-2007, 11:35 AM   #8
Big Bronze Rim
Well, if nothing else, get new pistons and have your machine shop install those rods onto the new pistons. IIRC when I was deciding what pistons I was going with i saw the 54C pistons were around $60 each and then you will need a ring set. I would make sure you dont need to bore before you go and order stock bore pistons.
Old 05-26-2007, 11:36 AM   #9
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
stock pistons or performance pistons?
babowc is offline   Reply With Quote
Old 05-26-2007, 11:45 AM   #10
benefitx
paid 85$ for the set...
i have my stock pistons that i pulled out in perfect condition...out of the SR im building that spun a bearing...crosshatched walls and everything , just one rod is bent maybe 4-5mm...so i bought these..oh and i bought a crank from him too which is in perfect condition...
i want to swap my good condition pistons onto these rods but i dont want to mess with the snap rings, then ill just have to replace them and no one sells them individually...
Old 05-26-2007, 04:16 PM   #11
projectRDM
projectRDM's Avatar
Snap rings take 3 seconds to remove, wrist pin another 10. You can swap all four pistons over to the new rods in under a minute.
FORMERLY R240NA
Old 05-26-2007, 04:22 PM   #12
benefitx
yeah but i cant use the same snap rings right? my pistons are in real good condition...good coat of black on the top..ringlands look ok too...just one rod is bent...so i bought this set
Old 05-26-2007, 08:36 PM   #13
benefitx
seller exchanged the rods/pistons for a different set , teehee.
Old 05-26-2007, 08:53 PM   #14
projectRDM
projectRDM's Avatar
Why not? They're designed to be removed and reinstalled.
FORMERLY R240NA
Old 05-26-2007, 09:23 PM   #15
benefitx
because maybe it will lose its snappyness and come off? johngriff said to replace them in the other thread..
Old 05-27-2007, 01:06 PM   #16
benefitx
the rods and pistons look really good, this set had bearings already on them to see if they were spun or anything...
Old 05-27-2007, 01:09 PM   #17
benefitx
do i plastigage the rod bearings also?
Old 05-27-2007, 04:25 PM   #18
Big Bronze Rim
Yes, you need to plastigauge both rods and mains.
Old 05-27-2007, 04:33 PM   #19
johngriff
johngriff's Avatar
You can re-use them.
And the SR's are probably better than the CA's. That was ME erroring on the CA.
But remember, I am knuts. As attested to by other forum members, I over complicate things. I'll only buy hardware from McMasterCarr for example. Replacement parts only from the dealer. It can be nauseating to some people how thorough I am.
Russ is probably right, they will probably be fine being re-used. As I say "if you've got it, drop the coin for it". You'll have to remove them anyways. And lord only knows i did something dumb like not get it all the way into the groove.
[email protected]
Old 05-27-2007, 06:00 PM   #20
benefitx
not getting it into the groove will probably cause problems...
i just bought some engine assembly lube made by permatex...its red in color in a little bottle...from autozone
and some blue rtv for the oil pan and water pump and stuff...
is this right??
Old 05-27-2007, 06:02 PM   #21
benefitx
plastigauge green right...
i just lay down a strip of it on the mains , put the crank in , put the caps on and torque down the girdle... and then take it all of and measure the strip? if its between ______ and ______ its good??
Old 05-27-2007, 07:48 PM   #22
johngriff
johngriff's Avatar
yeah, more or lesss, but you should plastiguage AFTER specing the crank/rod/journals.
Get permatex grey for all the everything. Chuck the blue or return it.
[email protected]
Old 05-27-2007, 07:50 PM   #23
benefitx
what!! everyone has told me Blue RTV is the shit...my brother said something about some black shit because its high temp...never heard of permatex grey tho..
Old 05-27-2007, 07:54 PM   #24
Big Bronze Rim
Yes, you will need to lay a piece of plastigage on each journal. It should be used as confirmation that your on track with the bearings you ordered and any crank work that was done. Make sure its nice and straight along the journal axis. I did my mains at the same time and each rod one at a time. You need to make sure the is NO OIL on the journals when using plastigage. You will use the scale on the wrapper the plastigage comes in to measure its compressed thickness. The tolerances are in the FSM, but I set my engine up a little loose, running .0015" on the mains and .0018-.002" on the rods.
Old 05-27-2007, 07:54 PM   #25
johngriff
johngriff's Avatar
http://www.permatex.com/products/aut...sket_Maker.htm
Nissan stopped selling/stocking/making (whatever), their grey RTV sealant, and simultaneously Permatex released this. It is certified by Nissan.
Blue is only supposed to be for Thermostat housings and waterpumps iirc, but it fails at all of those. PLUS grey looks the cleanest on a build, much more so than orange/blue etc...
**edit** or this, but its more expensive, and the can dies if you dont use it a whole lot.
[email protected]
Old 05-27-2007, 07:57 PM   #26
Big Bronze Rim
Yea, please don't use the blue, it isn't the shit and will look like butt. Get Permatex Grey like johngriff recommended.
Old 05-27-2007, 07:59 PM   #27
benefitx
ahh. alright..should of posted it earlier before i went out
Old 05-27-2007, 08:03 PM   #28
benefitx
when i go to buy plastigage ill get some ultra grey. thanks for the info
Old 05-28-2007, 09:22 AM   #29
projectRDM
projectRDM's Avatar
Ultra Grey or Ultra black is fine, black is high temp but you won't see a need for it anywhere except the oilpan. Grey is sensor safe, so you can use a dab of it on the CTS or other sensors/switches that thread into aluminum to seal them without the need for teflon tape. I use both for each purpose, then wait a day and go back with a razor to trim any excess off. Nothing looks worse than a gob of RTV hanging out between two parts.
FORMERLY R240NA
Old 05-28-2007, 11:56 AM   #30
benefitx
thanks...so i need ultra grey AND black??
