Old 05-26-2007, 05:13 PM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
front wheels centering back later than steering wheel centering.
I have a strange problem developing right now.
When I go through a slow corner with some speed and coming out of the corner, I feel front wheel centering back later than the steering wheel! As front wheel centers, it pushes the steering wheel further to the direction it is centering back to, therefore changing the direction of the car by itself. This kind of feeling doesn't happen when I turn the steering wheel to go into a corner. Only when I am exiting a corner.
These are my mod list on steering system.
Megan coilover front
Aluminium steering bushing.
Tein tension rod (more than an year old)
Tein tie rod end.
I am going through all of these but would like to know if anyone experienced anything like this.
jafero is offline   Reply With Quote
Old 05-26-2007, 05:46 PM   #2
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
sounds like an alignment issue
ecuastyle84 is offline   Reply With Quote
Old 05-27-2007, 11:14 AM   #3
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Sounds like some weird caster and toe problem.
Have you gotten an alignment since you installed your tie rods and tension rods?
Old 05-27-2007, 02:16 PM   #4
jafero
Yes, I did get an alignment done after installation.
This was a toe problem. Shit load of negative toe I found. I am trying to see whether tie rod inner or outer has moved. Thanks for your helps!
Old 05-27-2007, 10:02 PM   #5
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Yeah, you need close to negative toe.
You probably didn't threaded too much/ not enough thread into the outer end of the tie rod. I'm guilty of that as well.
It fucked up my entire alignment trying to get it into 0*.
Old 05-27-2007, 10:36 PM   #6
McRussellPants
uhh... if you can't set the toe to 0 or whatever you want theres something wrong with your car.
McRussellPants is offline   Reply With Quote
Old 05-28-2007, 02:34 AM   #7
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Check your steering rack bushings.
Nizzan4u2nv is offline   Reply With Quote
Old 05-28-2007, 04:34 PM   #8
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
yea everyone should be able to set the toe to 0. If not you did something wrong.
O3DigitalBath is offline   Reply With Quote
Old 05-28-2007, 11:40 PM   #9
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I have .015 toe out.
