Old 05-27-2007, 11:47 PM   #1
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
s13 17x9 fitment problems, s13
sup everyone, wanted to get some opinions of my fitment and what i encountered.
s13 fastback (stock fenders)
17x9+20 + 235/40/17 Federals (all around)
Tein HE's
Front - Ichiba hubs
Rear - S14 SE hubs
The wheel originally mounted barely without a spacer when it had no tire, after mounting the tire i had to use a 5mm spacer (see clearance bellow). It doesnt rub but it looks rather close. I also did a 5mm spacer in the rear.
Rolled front and rear fenders, relocated the harness, banged inside of the fender well, no rubbing.. concerened about possible future rubbing issues when the tire starts to flex at higher speeds. Car needs an alignment, since after the ES master bushing kit install everything was thrown off.. front camber is all the way negative right now.. hopefully with proper alignment i can pull back on camber a bit and still clear the fenders.. No outside pics yet as i'm still trying to decide if to raise the rear or drop the front some more? I wouldnt mind going lower but circuit sport midpipe is hanging pretty damn close to the floor.
From what i've researched many got away without spacers on HE's, for me it didnt work, yet other say that its almost a must.. not sure if it matters due to tire brand but in my case for sure it will not clear without a spacer. Any advice is greatly appreciated. Many tks in advance!
hybrid_eg is offline   Reply With Quote
Old 05-27-2007, 11:56 PM   #2
D1champ
D1champ's Avatar
D1champ is on the path to ruinD1champ is on the path to ruin
I would have gone with 225's in front.
D1champ is offline   Reply With Quote
Old 05-28-2007, 12:07 AM   #3
LB.Motoring
LB.Motoring's Avatar
thats what happens,
+20 offset isnt that great.
Robby Leuer
Old 05-28-2007, 12:09 AM   #4
Irukandji
Federals only come in 4x4 monster truck spec 45 sidewalls for 225s, so its 215s or 235s.
Just get a tiny spacer.
Irukandji is offline   Reply With Quote
Old 05-28-2007, 12:27 AM   #5
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
trust me when i say that'll fuck up your coils, it'll rub and rub bad, the tires will rub the coils and it'll spin and it'll rub, rub, rub
get some spacers, i'd post up pics of my 17X9 +27, 235/40/17, but i'm too lazy, it's on the Group Buy:MB motoring wheel section... i need at least 5mm on my jics to clear without worries, but i used 10mm... rears are not a problem of course
Wei240 is offline   Reply With Quote
Old 05-28-2007, 12:29 AM   #6
johngriff
johngriff's Avatar
Federals have a huge frame and usually just look goofy..
[email protected]
Old 05-28-2007, 12:35 AM   #7
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
i had 17x9+10 on 225.45..no rubbing on the coils, but rubbed on fender
now i have 17x9 +17, same tire size and didnt rub
on anything
markyboi is offline   Reply With Quote
Old 05-28-2007, 12:55 AM   #8
hybrid_eg
im at 17x9+15 now with that 5 mm spacer.. like i mentioned i dont see anything rubbing, there is little space left but not much, my only concern is for hard cornerning as the tire is bound to flex a little.. that little can hit that coil.. a quick fix would be wider fenders that i just dont dig, i know it will solve the prob right away. Perhaps try a different brand tire later?
I'll get some pics up tomorrow of outside hopefully maybe drop the front some rear and see where it will start to hit the fender and check exhaust clearance as well..
Old 05-28-2007, 01:08 AM   #9
Wei240
just by looking at your pics above, it really seems like the tire will rub on the coil, the rims won't ever touch, but the tires look like it positively would... after a while, if you notice rub marks on your springs, you'll know that you need couple more mm in spacers or run thinner tires
rears are not a problem with that size, no spacers needed
Old 05-28-2007, 01:13 AM   #10
Wei240
this rubs
and that's 17X9 +27 from the outside
+17 (fronts) from the outside
Old 05-28-2007, 01:17 AM   #11
hybrid_eg
many tks for advice, i will most definitely keep an eye on the coils and see what happens. As for rear only reason why i went with a spacer is to match the front and keep the track width the same as stock of course with bigger wheel/tire combination. Back is no probs at all.. plus i like the rear ride height.. :-) need oem sideskirts badly now.. :-)
Old 05-28-2007, 01:28 AM   #12
rps13sr20det
rps13sr20det's Avatar
rps13sr20det is making a name for him/her selfrps13sr20det is making a name for him/her self
this is a pretty interesting thread. I just recieved my work XD9's in 17X8.5 front and 17X 9.5.... Rear fenders have slight roll. fronts rolled...Put new cusco's zero's in this afternoon and the wheels are getting mounted with 225's in the front and 235/45's in the rear.......any guesses on if i'll be rubbin on anything.
rps13sr20det is offline   Reply With Quote
Old 05-28-2007, 01:33 AM   #13
Wei240
need to know offsets...
Old 05-28-2007, 02:06 AM   #14
Chasmoore04
Chasmoore04's Avatar
Chasmoore04 is making a name for him/her selfChasmoore04 is making a name for him/her self
Send a message via AIM to Chasmoore04 Send a message via Yahoo to Chasmoore04
just get a spacer. like a 30mm
Chasmoore04 is offline   Reply With Quote
Old 05-28-2007, 04:55 AM   #15
panama DRIFT
panama DRIFT's Avatar
panama DRIFT is an unknown quantity at this point
Send a message via AIM to panama DRIFT
you have a 5mm? try a 10mm spacer just my 2 cents
panama DRIFT is offline   Reply With Quote
Old 05-28-2007, 01:43 PM   #16
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
Yo Ismar,
Glad you finally got some tires put on, but I'm surprised how little clearance you ended up with... it may be just that HE's have the least clearance, as both my coils, with a bigger tire, were fine w/ a +20. I'd say just get a bigger spacer and run a little bit more camber, maybe push the fender out a bit more, and you'll be ok on a stock fender.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 05-28-2007, 01:51 PM   #17
Dousan_PG
Dousan_PG's Avatar
5mm is fine
but id get longer studs and run a 10
this type of stuff is over 3 years old if not more.
Aaron
Pink GodziRa
Old 05-28-2007, 01:57 PM   #18
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
Originally Posted by Dousan_PG View Post
5mm is fine
listen to aaron... i learned everything i know from him and lindsay...
funny thing is that i asked him this question 3 years ago...
you can also adjust your camber from the knuckle spindle on your tein he hybrid_eg... its the top bolt... the hole on the strut mount is eccentric....
or you can get extended studs and run 10mm... if not just add another 3mm on top of your 5mm once you get the extended studs...
how do you say that aaron??? oh yes...
done and done....
http://www.thenismoshop.com
swayray is offline   Reply With Quote
Old 05-28-2007, 02:10 PM   #19
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Yeah, sounds like you need to get either:
A) Extended studs and a spacer
B) Different wheels
C) Different Coilovers
I do remember hearing something about Teins have BAD wheel clearance. But I'm not sure who I heard it from so the word may be less credible.
Old 05-28-2007, 02:22 PM   #20
Ca_laurier
Ca_laurier's Avatar
Ca_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to allCa_laurier is a name known to all
johnny, you will be ok. I know for a fact you went with the same sizes that andrew did. 17x8.5 +22 in the front and 17x9.5 +28 in the rear
If your scared of your fresh pant being cracked oh well. your car is a garage queen anyways lol
but to the main topic. fuck the federals. Those tires are so think as it is. If you compare a 215/40 to a falken its insane. But you are going to have to roll your fenders and run spacers. why not run a 7-10mm spacer with more camber???
Ca_laurier is offline   Reply With Quote
Old 05-28-2007, 03:33 PM   #21
hybrid_eg
don,aaron,ray and others many tks for advice guys! i know its an old topic and i appologize for covering it once more. I'll try adjusting camber from knuckle and see how far this gets me. I still have plenty of room tire/fender clearance as i probably slightly pulled the fender while rolling. I already have extra extended studs for the front in case i need to run a little bigger spacer.. maybe either 7 or 10mm worst case scenario.. as for wheels no way i'm changing them :-) its either run these or run stock SE's :-) I'll look into different coils as last option but as of right now it looks like it will all work out fine. I will update this thread some more with new pics as soon as i get a chance.
Tks again all!
Old 05-28-2007, 03:36 PM   #22
idrum2loud
idrum2loud's Avatar
idrum2loud has a little shameless behavior in the past
stop buying bad offset wheels!!!!!! The wider the wheel, the lower the offset needs to be or else that will happen
getting old sucks
idrum2loud is offline   Reply With Quote
Old 05-28-2007, 04:38 PM   #23
swayray
swayray's Avatar
17x9 +20 is not that bad... its still better than some 17x9 +35 taiwanese crap....
Old 05-28-2007, 06:33 PM   #24
Ca_laurier
Ca_laurier's Avatar
true, on s13's you can run 17x10 with a +35 offset in the rear
i have just never seen a +20 offset have inner clearance problems like this
Old 05-28-2007, 06:36 PM   #25
Dousan_PG
Dousan_PG's Avatar
exactly its not bad wheels, just that size doesnt clear ALL coilovers, some it will, some it wont
HE's i had to run 9 +10
cool deal.
Aaron
Pink GodziRa
Old 05-29-2007, 12:08 PM   #26
rps13sr20det
17X9.5 and +17 in the rear with 17X8.5 +22 in the front..... it looks gross with no roll. GOD...doing a good roll this weekend.....
Old 05-29-2007, 12:17 PM   #27
TheSquidd
TheSquidd's Avatar
I run 17x9 +15 in front, and if I don't use my spacer, I have like 3mm of spring clearance.
TheSquidd is offline   Reply With Quote
Old 05-29-2007, 01:19 PM   #28
BILLYhoang
BILLYhoang's Avatar
BILLYhoang is on a distinguished road
Send a message via AIM to BILLYhoang
god dang thats close . *crossed fingers * hope i get the right size . damn !
BILLYhoang is offline   Reply With Quote
Old 05-29-2007, 01:25 PM   #29
hybrid_eg
to those that are running similar size offsets like me what coilovers are you running? i knew HE's wouldnt have a good clearance period, but what other models would have say optimal wheel to coilover clearance?
tonight i will adjust the knuckle and see how far this gets me, and if that doesnt help i'll try 8mm first then like aaron said 10mm up front will clear like there is no tomorrow :-)
Old 05-29-2007, 01:36 PM   #30
Ca_laurier
Ca_laurier's Avatar
no what i was getting at was a higher offset on a 17x9. almost looks like its close to +30
