Old 05-28-2007, 10:00 AM   #1
nyrps13
nyrps13 is a well-known jackass
s13 Need Help S13 Sr20det idling problem
i did the S13 black top swap in my 240sx. my car starts and everthing revs through all rpm freely but wont idle, once i let the rpm drop below 1,000 it dies out. my shop told me it maybe the AAC VALVE (idle air control valve) i wanted to know if it is the same part from my old motor the KA24 DOHC
PLEASE HELP !!
nyrps13 is offline   Reply With Quote
Old 05-28-2007, 10:02 AM   #2
georgesal
georgesal's Avatar
georgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to beholdgeorgesal is a splendid one to behold
it could be that or it could also be your throttle plate closes ooo much at idle, there is a lithe screw and nut thing on the bottom of the throttle body adjust that so you plate stays a lil more open
georgesal is offline   Reply With Quote
Old 05-28-2007, 10:12 AM   #3
nyrps13
hmm okay i guess i can try that but would you happen to know if the SR AAC is the same as the KA AAC VALVE
Thank you
Old 05-28-2007, 10:36 AM   #4
Mlogue84
Mlogue84's Avatar
Mlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfectionMlogue84 is close to perfection
Send a message via AIM to Mlogue84
Throttle position sensor?
Mlogue84 is offline   Reply With Quote
Old 05-29-2007, 03:24 AM   #5
blitz180
blitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-knownblitz180 is making his/her stupidity well-known
Send a message via ICQ to blitz180 Send a message via AIM to blitz180
KA AAC and SR AAC are not the same.
The TPS is from a 91 (or similar) SE-R Sentra, incase you decide to try that.
blitz180 is offline   Reply With Quote
Old 05-29-2007, 11:04 AM   #6
tastycakeman
tastycakeman is making his/her stupidity well-knowntastycakeman is making his/her stupidity well-knowntastycakeman is making his/her stupidity well-knowntastycakeman is making his/her stupidity well-knowntastycakeman is making his/her stupidity well-known
CAS
rotate it!
tastycakeman is offline   Reply With Quote
Old 05-30-2007, 08:03 PM   #7
nyrps13
okay thanks for the tip guys but it does rev slugish between certain RPM's car is pissing me off about to part it out... GRR!!!!!!
